Center of mass for two small particles
The discussion focuses on determining how far particle m1 travels before colliding with stationary particle m2, given that they attract each other with a force inversely proportional to the cube of their separation. Initially, it is noted that the center of mass (CoM) of the system is moving due to the motion of m1, which leads to confusion about its position at the time of collision. The correct approach involves calculating the CoM's position using the formula r_cm = (m2*d)/(m1+m2) and incorporating its velocity, v_cm = (m1*v)/(m1+m2), to find its displacement over the time interval. Ultimately, the final position of m1 at the moment of collision is expressed as r_cm + v_cm(t1 - t0). This analysis clarifies the movement of the CoM and its impact on the collision outcome.
myko
1. Two small particles of mass m1 and mass m2 attract each other with a force that varies with the inverse cube of their separation. At time t0 , m1 has velocity v directed towards m2 , which is at rest a distance d away. At time t1 , the particles collide.
How far does m1 travel in the time interval (t0 and t1 )? Express your answer in terms of some or all of the variables m1, m2, t1, t0, v, and d
3. The Attempt at a Solution . I think it can be solved by noticing that since there are no external forces acting on the system, the center of mass will not move. So finding it, would give the final position of the particles at t1. Taking position of m1 at t0 as reference point:
$$r_{cm}=m2*d/(m1+m2)$$
But this is wrong. Could someone point me where the mistake is?
But the centre of mass IS moving! One of the bodies is moving, the other is stationary. At the moment they contact, our interest in the situation ends.
Ya. I see it. Thankyou. So then, would it be correct to proceed this way?
Sincé the center of mass is moving with velocity v and there is no external forcé acting, it will keep moving same velocity. So it will travel distance $$d_{cm}=v(t1-t0)$$ from it's initial position.
So at t1 it will be at $$r_{cm}=m2*d/(m1+m2)+v(t1-t0)$$.
At this momento particles collide, so it will be the position of m1. Is this correct?
EDITED
I think that's right, the CoM will not change its velocity while the pair interact.
Not velocity v.
Correct answer is $$\frac{m_2\cdot d}{m_1+m_2}+v_{cm}(t_1-t_0)$$ with $$v_{cm}=\frac{m_1\cdot v}{m_1+m_2}$$.
