Calculating Centre of Mass of a Uniform Object
To calculate the center of mass of the given uniform object, it is suggested to break it down into five squares, each with a side length of 'a'. The x-coordinate of the center of mass can be determined by calculating the moments of the entire rectangle and subtracting the moment of the missing square. The y-coordinate can be found similarly, using the same principles of moment calculation. The discussion emphasizes the importance of considering the entire rectangle's mass and the effect of the gap on the overall center of mass. This approach provides a clear method for solving the problem effectively.
BMcC
Calculate the centre of mass of the object shown below, assuming uniform density
Object: http://i.imgur.com/zuOUyL7.gif
Assume the origin, O, at the lower left, and the positive x-axis pointing to the right.
1) What is the x coordinate of the centre of mass, in terms of a?
2) If the positive y-axis points up along the page, what is the y coordinate of the centre of mass, in terms of a?
So obviously you can break the object into 5 squares, each with a length and width of a and a centre of mass in the middle of the squares. I've done this and tried starting at the origin by adding the masses and positions up according to this formula given by my professor:
Xcm = x1m1 + x2m2 . . . divided by the sum of the masses, m1 + m2 . . .
I'm not sure how to take that gap into account. Should I find the centre of mass of the full rectangle and then subtract the area of the missing square? I don't quite know how to go about doing that.
Thanks in advance!
Remember, the gap is not there. What does this fact tell you about how to handle it?
You seem to know what the center of gravity of a square is. Can you make the leap and figure out what the center of gravity of a rectangle is?
These are your two hints. Show some work on this problem.
That's certainly the easiest way. Find the moment of the whole rectangle about O, subtract the moment the missing square would have if it were present, then divide by the mass of the object.
