Centripital Force and Springs Combined
  • Thread starter Thread starter Jennings
    Force Springs
The discussion revolves around a physics problem involving a mass hanging from a spring that is rotating, leading to the need to calculate the angle with the vertical, the speed of the ball, and the work done on the shaft. Participants clarify that the net force acting on the mass is the vector sum of the spring force and gravitational force, emphasizing the importance of breaking these forces into components to solve for the angle. The conversation includes attempts to derive equations for force balances in both horizontal and vertical directions, ultimately leading to the calculation of the angle, which was found to be approximately 86.4 degrees. The participants express uncertainty about the correctness of their calculations and seek further guidance on solving for speed and work done. The thread highlights the collaborative effort to understand the dynamics of the system involving centripetal force and spring mechanics.
Jennings
1. Homework Statement
(Attached is an image depicting the situation)
A ball of mass m = 1.50kg is hung from a spring attached to a shaft. The length of the spring with the mass hanging from it is Lo = 50.0cm. The shaft then starts to rotate such that the spring stretches to a length L = 65.0cm. The spring constant of the spring is k=1450N/m.
A) At what angle theta does the rotating spring make with the vertical
B) How fast is the ball moving
C) How much work had to be done on the shaft to get the ball moving at the angle and speed given in parts a and b
Springs : Fs = -kx
Centripital Force : Fc = mv²/r
First thing I did was solve for the length of the spring at equilibrium (assuming the spring is massless). First I solve for the change in distance due to the mass attached.
mg = kx
mg/k = x = (1.50kg)(9.81m/s²)/(1450N/m)
x = 1.015cm
Length at Equilibrium
50.0cm - 1.105cm = 48.99cm
Now that I know the equilibrium length I will find the total force being applied to the spring since the length is known.
Change in length from equilibrium
65.0cm - 48.99cm = 16.01cm = .1601m
The total force acting on this spring is
F = kx = (1450N/m)(.1601m) = 232.1N
I don't even know if I'm on the right track with this. I have a free body diagram that I will post, but again I have no idea if I'm on the right track.
If I've made any mistakes please let me know.
I don't know how to attach the file of my free body diagram
So far you are on the right track.
Chet
Chet
Hello Chestermiller. In order to solve for angle theta Atleast one more component of the force must be known. Weight is straight down and I'm guessing the centripital force must make up rest of the net force. Isn't centripetal force is purely horizontal?
Please write out your force balances on the mass in the x and y directions.
Chet
Here is my attempt at solving for the centripetal force. I don't think its correct but it's all I know how to do
How come your force balance equations don't have the components of the spring force acting on the mass in the horizontal and vertical directions?
Chet
Likes Jennings
Chet
I thought that the spring force is the net force? That's how I was able to find the net force. Please clarify
It would be wise to see Fc as a resultant force, i.e. the net force. It is the sum of the two forces that work on the mass: one from gravity, the other from the spring.
The resultant force is what makes the mass follow a circular trajectory.
You calculate its magnitude (you need that for B.), but in A) the exercise asks for an angle...
The spring force is not the net force. The net force is the vector sum of the spring force and the weight. Now please, write out the force balances in the horizontal and vertical directions in terms of the horizontal and vertical components of the spring force, and the weight of the mass.
Chet
Sounds good. Only there's one problem. I don't know the direction of the spring force, only its magnitude.
What I know :
Magnitude and direction of the weight
Magnitude of the spring force
Don't know:
Direction of spring force
Magnitude and direction of resultant centripital force.
What can we do?
Is there a trick?
What I know :
Don't know:
What can we do?
Is there a trick?
Wait hold on I think I got something
No, there's no trick. You express the components of the spring force in terms of sine and cosine of theta. Then you write the force balances. Then you solve for theta.
Chet
Chet[/QUOTE]
Chet
Something else needs to be known.
The sum of forces in the y direction must be 0 so that we can have an equation.
(Fs means force of spring)
ΣFy = Fscosθ - mg
ΣFx =Fssinθ
If the sum of forces in the y direction = 0 then we have our equation. Otherwise i don't kneo
ΣFy = Fscosθ - mg
ΣFx =Fssinθ
Well, then you have your equation for the y direction. That gives you theta.
What is your force balance equation for the x direction?
Chet
First attachment is solving for the angle which I found to be 86.4 degrees. (It really doesn't look that way in the picture I hope I didn't do it wrong). Second attachment is the sum of forces in direction x which is also the magnitude of the centripital force
Looks good. Now on to b) and c) ?
