tobix10
- 7
A loop of flexible chain, of total weight W, rests on a smooth, frictionless right circular cone of base radius r and height h. The chain rests in a horizontal circle on the cone, whose axis is vertical. Find the tension in the chain.
Virtual work, but I've done it with Newton's ## F = ma ##.
I considered a part of a chain that spread on an arch of angle ## \Delta \theta ## (angle is very small) The forces ## T ## on each end of arch exert horizontal force ## 2T \sin(\frac{\Delta \theta}{2}) ## which has to be equalized by horizontal component ## N_{x} ## of normal force.
Equations are:
## N_{x} = T \Delta \theta ##
## N_{y} = W \frac{\Delta \theta}{2 \pi} ##
## \frac{N_{x}}{N_{y}} = \frac{h}{r} ##
Solution is:
## T = \frac{W}{2 \pi} \cdot \frac{h}{r} ##
Is this answer correct? Any tips how to handle this problem using principle of virtual work?
