Calculating dQ/dt: Chain Rule Applied
jamesbob
Question: Let
Q = \sqrt{x^2 + y}e^t​
where (for t > or = 0)
x = \sqrt{1 - e^{-2t}}​
and
y = 2 - e^{-2t}​
Using the chain rule calculate dQ/dt, expressing your answer in as simple a form as possible. My work so far
Subbing in values of x and y:
Q = \sqrt{1 - e^{-2t} + 2 - e^{-2t}}e^t = \sqrt{3 - 2e^{-2t}}e^t
Now applying the product and chain rule:
u = (3 - 2e^{-2t})^{\frac{1}{2}} \left chain \left rule \Rightarrow u = z^{\frac{1}{2}} \left z = 3 - 2e^-2t
\frac{du}{dz} = \frac{1}{2\sqrt{z}}, \left \frac{dz}{dt} = 4e^-2t
So \frac{du}{dt} = \frac{4e^{-2t}}{2\sqrt{3 - 2e^{-2t}}}
As for v, v = e^t, \left \frac{dv}{dt} = e^t
So \frac{dQ}{dt} = \sqrt{3 - 2e^{-2t}}e^t + \frac{4e^{-t}}{2\sqrt{3 - 2e^{-2t}}}
Is this right so far and can it be simplified further?
jamesbob said:
Question: Let
and
y = 2 - e^{-2t}​
My work so far
Looks good to me. Theoretically you would want to remove the square root from the denominator and add the two expressions, but I personally don't see that that actually simplifies anything.
-Dan
Thanks very much :smile:
While a perfectly valid technique, I think part of the point of this problem is not to do such a substitution.
Hmm, i see, so would i just do the chian rule keeping x and y in, and then sub values in right at the end?
Or maybe not even sub in the values at all -- the final result might (or might not) look nicer in terms of x and y!
