Challenge Connecting Multiple Smartphone Mic's Simply & Quickly
The discussion revolves around the challenge of connecting multiple smartphone microphones for recording a meeting with minimal effort from participants. Key ideas include using technologies like NFC, Bluetooth, or a unique URL for quick connections without requiring app installations. Suggestions also mention the possibility of setting up a conference call, although concerns about feedback and recording capabilities arise. Participants consider using WiFi video conferencing as a potential solution, emphasizing the need for simplicity and reliability. The goal remains to create a seamless experience that requires little to no action from the other attendees.
Dutch Nomad
Dear Readers,
I'm facing a pretty interesting challenge, which is: "How to connect multiple smartphone mic's in the quickest and simplest way?"
Here is a use case. I go into a meeting with a group of random (strangers) that all have smartphones, Android, iOS, Windows. Now I want to record this meeting and in doing so I would like to leverage the mic's of all the phones in the room. How can I get the strangers phones to connect with my system, or maybe the cloud, to capture all the recordings in one platform. The main difficulty being that the other people in the meeting do not want to spend time installing an app of any kind. Basically I want them to notice the least possible of the whole operation. They should have to do little to nothing.
My ideas:
- Using the android beam technology by holding phones against each other (only works on Nexus though)
- Using some sort of bluetooth system.
- Maybe I have a unique URL that I can type into a webserver on each phone.
If you have any thoughts, ideas, suggestions on this challenge, feel free to comment!Peter
Can you set up a conference call with all the included phones? They probably would all have to have their volumes turned down so they don't cause feedback with each other.
yeah using Skype in conference mode
not sure if/ how it could be recorded tho
Hey,
Thanks for the answer. It's not the ideal solution because the people would need to hold their phones on their ear all the time and like Davenn mentions, I'm not recording this.
Here is another thought: One person initiates the conversation and has a number that the other guys can send a text message to. Now there needs to be a way to connect these people with the first person by using the received text messages to connect everyone and turn on their mic's!
Thanks for replying!
It would indeed be something similar to Skype but then with recording. I'm still thinking how it could be easier than having to use Skype though. Maybe using NFC (near field communication) or something alike. It should basically be the simplest way to connect phones ever. Bluetooth is not bad, but it's not the most reliable either :s
I Googled WiFi video conferencing and found a lot of hits. You could operate without the vision and the data rate would be significantly lower.
Earphones would remove the problem of howlround.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
