Challenging problem involving special relativity
The discussion revolves around a physics problem involving the creation of massive elementary particles through proton collisions. It highlights that during a perfectly inelastic collision between two protons, not all kinetic energy of the incoming proton contributes to the mass of the resulting particle due to momentum conservation. The key equation derived shows that the energy available for creating a product particle is limited, leading to a non-linear relationship between the increase in kinetic energy and the mass of the created particle. The participant expresses frustration with their attempts to apply conservation laws and energy-momentum relationships, indicating a potential misunderstanding of the underlying principles. The problem emphasizes the complexities of special relativity in particle physics.
Kyle.Nemeth
The creation and study of new and very massive elementary particles is an important part of contemporary physics. To create a particle of mass M requires an energy Mc2. With enough energy, an exotic particle can be created by allowing a fast-moving proton to collide with a similar target particle. Consider a perfectly inelastic collision between two protons: an incident proton with mass mp, kinetic energy K, and momentum magnitude p joins with an originally stationary target proton to form a single product particle of mass M. Not all the kinetic energy of the incoming proton is available to create the product particle because conservation of momentum requires that the system as a whole still must have some kinetic energy after the collision. Therefore, only a fraction of the energy of the incident particle is available to create a product particle. (a) Show that the energy available to create a product particle is given by Mc2 = 2mpc2√1 + K/2mpc2. This result shows that when the kinetic energy K of the incident proton is large compared with its rest energy mpc2, then M approaches (2mpK)1/2/c. Therefore, if the energy of the incoming proton is increased by a factor of 9, the mass you can create increases only by a factor of 3, not by a factor of 9 as would be expected.
E2 = (pc)2 + (mc2)2
E = K + mc2
I started this problem numerous times by modeling the two protons and the product particle as an isolated system and stating that pi = pf by the conservation of momentum. I then proceeded to use the energy-momentum relationship to find expressions for pi and pf. From there, I figured I'd be able to find the fraction of energy that goes into creating the product particle but after MANY many attempts, it seems I've just been running in circles. There seems to be something that I'm missing and I can't pinpoint what it is.
Here's what I did:
Ei2 = pi2c2 + (2mpc2)2 is the initial energy of the proton-proton system.
Ef2 = pf2c2 + (Mc2)2 is the final energy of the proton-proton system.
I started by solving for pi and pf and then used pi = pf. From there I attempted to solve for Mc2 but it seems that this has led me awry.
Use units with c=1.
Given:
E1=sqrt(p^2+m^2)
p1=p
E2=m
p2=0
Use energy and momentum conservation to determine Ef and pf of a product particle with mass M:
Ef=sqrt(M^2+pf^2)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
10K
