Change of variables cylindrical coordinates
manjum423
Let S be the part of the cylinder of radius 9 centered about z-axis and bounded
by y >= 0; z = -17; z = 17. Evaluate
\iint xy^2z^2
So I use the equation x^2 + y^2 \leq 9, meaning that r goes from 0 to 3
Since y \geq 0, θ goes from 0 to ∏
So the integral looks like this:
\int_0^∏ \int_0^3 \int_{-17}^{17} (rcosθ)(rsinθ)^2 z^2 r dzdrdθ
And I get:
\int_0^∏ \int_0^3 \int_{-17}^{17} r^4 cosθsin^2θ z^2 dzdrdθ
I'm having trouble evaluating this integral because for the \int_0^∏ cosθsin^2θpart. I get 0 (When u=sinθ by u-substitution and you get (1/3)sin^3θ from 0 to ∏)
Basically I would like to know if my limits and my setup is correct, and if anyone can help me out with a solution I would be grateful.
Well, firstly, the range of the dr-integral should be 0 to 9 not 0 to 9 because we're dealing with the cylinder of radius 9, not the equation x^2+y^2 <= 9.
But that won't affect the problem, I just did this myself and I also got 0. Unless someone else can point out a mistake we both made, I think that's the answer.
Edit: That makes sense, I think, because the equation w=xy^2z^2 is symmetric across the y axis.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
