Changing the order of integration
  • Thread starter Thread starter a1010711
    Integration
a1010711
Change the order of integration in the following double integral
integral from o to a, integral from 0 to sqrt(2ay-y^2) f(x y) dx dy
so i can see its a semi circle with center at (0,a)
x= sqrt(2ay-y^2) can be expanded by squaring both sides. then completing the square x^2+(y-a)^2=a^2 which is a cirle of radius 'a', center at (x,0)
then I am not sure what to do.. how do i integrate with respect to y first,,then x? how do i set this up
The center of the circle is at (0, a), not (x, 0).
In the original iterated integral, x ranges from 0 to sqrt(2ay - y^2), or from the y-axis to the right half of the circle. y ranges from 0 to a, so the region of integration is the lower right-hand quarter of this circle.
When you change the order of integration, the y values will need to range from the lower part of the circle up to the line y = a, and the x values will need to range from the line x = 0 to the right hand edge of the circle.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
