Charge Conservation: A+2 & B+7 → A+5 & B+5
When two conductors A and B with charges +2 and +7 respectively touch and separate, they cannot each have a charge of +4.5 due to charge quantization, which prohibits fractional charges. Instead, the charge distribution will adjust to maintain conservation of charge, resulting in one conductor having +4 and the other +5. This occurs because the system must account for all electrons, leading to a shift in charge distribution when an odd number of electrons is present. The final charge on each conductor is influenced by thermal noise, giving each a 50/50 chance of having the extra charge. Understanding these principles is crucial for accurately analyzing charge interactions in conductive systems.
Ed Quanta
Now suppose we have two conductors A and B. A has a charge of +2 and B has a charge of +8. If we let the two conductors touch and then separate them, each will have a charge of +5. This is because charge is conserved and will flow between the two conductors until each have equal charges.
Ok, so how would this change if instead of B having a charge of +8, it had an initial charge of +7. Now if let the conductors touch and separate them, each of them cannot have a charge of +4.5 because charge is quantized and there is no such thing as half of an electron. So what would happen? What would be the charge on each conductor?
When you say a charge of do you mean in units of e?
This is confusing. If you are talking in units of e then you describing basically two nuclei of Z=2 and 8 "touching". This is nothing like touching 2 macroscopic objects of some charge.
can you explain a bit more what you mean?
Wait, sorry do you mean a macroscopic conductor with net charge of +2e and +8e
Yeah
Well, the net charge for A and B in isolation would be +8e and +7e. This is the sum over ALL the charges of the system where all the positive nuclei are canceled by all but 8 and 7 electrons.
So you are not dealing with an 8e and 7e system, you have to take into account all the electrons.
When A and B approach in the first case as you say, the electrons will equilise the charge on each body. In the second case where there is an odd number of electrons and and even number of protons for the whole system (A+B) then the charge distribution of A and B will shift to accommodate the charge imbalance.
There would be a charge of 4 electrons on one and a charge of 5 on the other. Assuming that your spheres were absolutely perfect identical spheres then there would be a 50/50 chance of each having the "extra" charge. It would be determined simply by thermal noise.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
