Charge deflection in ink jet printer
In an inkjet printer, ink drops are charged and deflected by an electric field to create patterns on paper. The problem involves calculating the charge required for a drop to be deflected 0.30 mm while traveling through a uniform electric field of 9.1 x 10^4 N/C. The force on the drop is determined using F = qE, and the acceleration is derived from kinematic equations. After calculations, one participant arrived at a charge of 5.268 picoCoulombs, but there was some disagreement on the accuracy of this result. The discussion highlights the complexities of applying physics equations to solve for charge in an electric field scenario.
steve1234
In an inkjet printer, letters are built up by squirting drops of ink at the paper from a rapidly moving nozzle. The pattern on the paper is controlled by an electrostatic valve that determines at each nozzle position whether ink is squirted onto the paper or not. The ink drops, 15 μm in radius, have a mass of 1.41 x 10-11 KG leave the nozzle and travel toward the paper at 20 m/s. The drops pass through a charging unit that gives each drop a positive charge q when the drop loses some electrons. The drops then pass between parallel deflecting plates 2.0 cm in length where there is a uniform vertical electric field with magnitude 9.1 x 104 N/C. If a drop is to be deflected 0.30 mm by the time it reaches the end of the deflection plate, what magnitude of charge must be given to the drop? (Answer in pC -- pico Coulombs.)
F = (k*q1*q2)/r^2 , where k=8.99e9
E(Electric field) = F/q
I'm pretty stuck on this one and any help on how to do this or to get me started would be appreciated.
What is the force exerted on a charge in an electric field? Your second equation should give you the clue.
F=qE?
how would this help you to find this force when we are missing two variables?
first we found time t = d/v t=.001s
X = Xo + Vot + .5at^2 to find our a
F=ma=qE and solve for q, q=ma/E
final answer came out to be 5.268 picoCoulombs, does that sound correct?
hey did that answer work for you?
Sounds ok but I get a different answer. What did you get for a?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
