Charged particles - magnitude of force
hoseA
http://img77.imageshack.us/img77/5310/chargedparticles7of.png
What is the magnitude of the force on a
-1.2 muC charge placed at a point 1.6 cm to the left of the
middle charge?? Answer in units of N.
This is what I did:
I used Fx = k*|Q|*(qx/r^2)
Q= 1.2*E-6
I plugged in 8.6*E-6 into the above equation (keep in mind i used 3.7cm-1.6cm =2.1 cm --> .021m) and got F1=210.320898
I plugged in 4*E-6 into the above equation (i used .016m) and got F2=168.5165625
I plugged in -1.2*E-6 into the above equation (i used .016+.032=.048m) and got F3 = -5.61721875
Then for F final = -F1 + F2 - F3 = -36.187
Since it asks for magnitude I plugged in 36.187. It came up as wrong... where did i go wrong??
It would be great if someone can offer any help within the next 3 hours.
According to the way you've defined F1, F2 and F3, your net force should be
Fnet = -F1 + F2 + F3
which comes out as 47 something Newtons.
Wow, that was it. Thanks A LOT! People like you make this site awesome. Thanks again. :approve:
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
