Charging 12V Batteries: Solar Panel and Electric Motor Q&A
A 9-watt solar panel rated at 12V can produce up to 20V in optimal conditions, making it unsuitable for direct charging of a 12V battery without additional circuitry. A DC-DC converter circuit is recommended to ensure safe and effective charging, along with a diode to prevent battery discharge into the panel at night. For using a 24V electric motor as a generator to charge a 12V battery, it can work if the output is limited with a resistor, and a diode is also required to prevent reverse current. Proper monitoring of charging current is essential to avoid overcharging the battery. Overall, both charging methods require careful setup to ensure safety and efficiency.
Clive_
Hi,
I have some questions please...
Can I use a 9 watt solar panel to charge a 12v battery directly? Do I need a rectifier or is the loss back into the solar panel too small to worry about?
Also, can I use a 24v electric motor (permanent magnet generator) to charge a 12v battery - or is it likely to cause damage to the battery?
Thanks,
Clive.
Clive_ said:
Hi,
Thanks,
Clive.
What is the output voltage range for your solar panel?
Hi,
The solar panel is 12v 9w rating. Though the meter shows 20v in good conditions (and between 2-6amps)
Clive.
Clive_ said:
Hi,
Clive.
So the answer is no, you shouldn't use the output of the solar panel to directly try to recharge a 12V battery. You should put a circuit between the solar panel and the battery to ensure that the charging voltage is the best possible (and safe) for the battery.
A boost-buck or Sepic DC-DC converter circuit would be a good fit for this job. You can learn more about them on wikipedia.org, or from most switching power supply books.
The open circuit voltage gets up to 20 volts in bright sunlight, so it is capable of charging a 12 volt battery. The voltage will drop to near the battery voltage when the two are connected.
You will need a diode between the two (with the cathode connected to the battery and the anode connected to the solar panel) so that the battery does not discharge into the solar panel at night.
Then, you will need to time the charging to ensure the battery is not overcharged. Put a current meter in series with the diode to check the charging current. Then divide the Amp-hour rating of the battery by this charging current to get the time it would take to fully charge this battery if it is not being used. If it is being used, there may be no need for this.
If you have a cheap way of rotating the motor, you can use it as a generator and it will give a bit less than 24 volts out at the rated RPM. You would need to limit the current with a suitable resistor. A 24 volt auto lamp between the generator and the battery would be OK for this.
And, as above, you would need a diode from the motor/generator to the battery. This is so that the battery doesn't try to drive the motor as a motor when the rotation is removed.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
