Charging of capacitors in series
When two capacitors of equal value are connected in series across a voltage source, the voltage across each capacitor in steady state will be half of the total voltage applied, resulting in 5V for a 10V source. Reducing the capacitance decreases the time the bulb glows during charging, but the steady-state voltage remains the same at 5V. If open switches are used instead of capacitors, the voltage across each switch in steady state cannot be definitively determined due to the negligible capacitance and lack of steady-state current. The presence of leakage current in real capacitors can also affect the voltage distribution. Therefore, measuring voltage across switches or capacitors in this scenario is complex and may not yield accurate results.
Nimbus2000
Hello everyone, I have a doubt about charging of capacitors in series. Suppose I connected two capacitors of same value, say,1 mF in series and put a bulb in series with them and applied a voltage 10V across the series. In steady state, the voltage across each capacitor will be 10/2=5V. Right?
The bulb will glow for a short time while charging the capacitors. Now, if I changed the capacitance to 1nF, still there will be 5V across each capacitor in steady state. Right? The bulb will glow for shorter time now(may not even be visible). So, as we go on reducing the capacitance, the glowing period of the bulb goes on decreasing but in steady state, voltage across each capacitance remains same 5V. Now, instead of capacitors, I just put two open switches in the circuit, will the voltage across each switch be 5V in steady state? I know the capacitance of the switch will be very small, but not 0. If no, how does the capacitance value affect this? Because, the voltage will be 5V, same for 1mF capacitor and 1nF capacitor. Instead if I just put two open switches, will it be same? Thanks in advance.
For the voltage sharing to happen, you must assume a value of capacitance, even for the case of the open circuit switch. And with these very small values of capacitance, you will need a current sensor capable of measuring the very short pulse and a voltmeter having extremely high resistance.
Maybe. Since no steady state current is flowing, there is no way to predict the voltage across each capacitor. For real capacitors the leakage current will determine the voltage across them.
Again, there is no way to tell (and if you measure the voltage, you are interfering with the circuit).
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
