Checking the divergence of a function
chi-young
Check the divergence theorem using the vector function V = r^2 \hat{r} + sin(θ) \hat{θ} which is expressed in spherical coordinates. For the volume use a hemisphere of unit radius above the xy-plane (see figure below) (picture not shown, but I integrated r: 0 to 1, theta: 0 to pi/2, and phi 0 to 2pi)
∫(Div V) d\tau = \oint V da
(Divergence Theorem)
I did the RHS first because it's simpler. given da = R^2 sin(θ) dθ dψ \hat{r} and R = 1
\oint V da → ∫sinθd from 0 to pi/2 * ∫dψ from 0 to 2pi, which is of course, 2pi.
I assume that because of it's simplicity, this side must absolutely be correct. Unfortunately, the LHS is much harder.
First I find Div V = 4r + 2cos(θ)/r, then I use d\tau = r^2 * sinθ dr dθ dψ
to obtain ∫ ( 4r + 2cos(θ)/r ) * r^2 * sinθ dr dθ dψ.
Next I integrate with respect to r, 0 to 1, to get sinθ (cos+1) dθ dψ. This is where it gets weird.
I integrate theta from 0 to pi/2 but I get 3/2. Since phi is from 0 to 2pi, and there are 0 phi terms, the answer must be 3pi. But this does not equal the LHS, which must be correct!
I have been doing this for a couple of hours and I cannot think of a problem. Please help!
Are you sure you're integrating over the entire boundary surface? Perhaps you're forgetting something...
Likes 1 person
Done, thanks. =)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
