Chemistry and properties of small engine motor oils
The discussion focuses on comparing the properties of engine oils used in lawnmowers and snow blowers, particularly in relation to their carbon chain lengths and intermolecular forces. It highlights that oil viscosity changes with temperature, affecting lubrication efficiency; oils may become too thick in winter or too thin in summer. The importance of selecting oils with appropriate carbon chain lengths is emphasized, as longer chains lead to higher melting and boiling points, impacting performance in extreme temperatures. Both oils serve to lubricate and cool the engine, necessitating specific properties for effective flow at startup and during operation. Understanding the relationship between carbon chain structure and intermolecular forces is crucial for choosing the right oil for each machine.
projection
Compare the properties of a engine oil used in your lawnmower with that used in a snow blower. relate these properties to the intermolecular forces in each type of oil.
i think this has something to do with carbon chains and how in winter the oil may get thicker and become pasty in the engine and how in summer it may get too thin and not be able to lubricate the pistons?
i am not too sure about this one. some help is greatly appreciated.
you're on the right track, would you use the same oil for both machines? what property are you looking at to help you choose which oil to use in which machine.
What is it about the structure of the carbon chains that will help you decide which oil to use?
the longer the chain is, the higher the melting and boiling point. so if the chain is too big the oil may become pasty in winter and will need a really hot winter to make it prefectly lubricant. so you want engine oil with a medium size carbon chain?
The problem asks to "Compare the properties of a engine oil used in your lawnmower with that used in a snow blower. relate these properties to the intermolecular forces in each type of oil."
Carbon chain length is not a property but gives rise to some. Talk a little bit about the intermolecular forces in each type of oil.
Both of these oils are used both to lubricate the engine and to cool it (these engines have no radiator). One is designed to work in the summer and the other in the dead of winter when it is extremely cold. They both have to flow just after the engine is started and when the engine is hot. What properties are important in these cases? What type of intermolecular forces give rise to these properties?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
