Drizzy
- 210
- 1
Why does my book say this is wrong?
Drizzy said:the current is probably going to be low because the volt meter has a high resistance. But why is it incorrect?
Drizzy said:my book: it is wrong to have an amp meter parallell because its resistance is so low that the amp meter could burn (too much current flowing through it). But how can the currrent be high if the volt meter has a high resistance?
This is difficult to answer, without answering the question, which is against forum rules.Drizzy said:my book: it is wrong to have an amp meter parallell because its resistance is so low that the amp meter could burn (too much current flowing through it). But how can the currrent be high if the volt meter has a high resistance?
Drizzy said:okay now I know what you mean but my book is saying that the amp meter is going to burn and that's the part i don't get
Does it say the ammeter will burn up in the circuit you've posted, or is this "burning up" mentioned somewhere else?Drizzy said:i can't because it is in swedish so i am translating it :(
Drizzy said:what happens if we switch places with V and A? So the amp meter is in series and the V meter is in parallell? now the amp meter is going to burn right? because the current is too high
The clarification indicates your book is correct. It was NOT referring to that specific circuit.Drizzy said:okay thanx! I am going to ask my teacher tomorrow i have been thinking of this non stop
What is its internal resistance?Drizzy said:okay but I still don't get why an amp meter is going to burn up if it is paralllell
And if you put an ammeter across a resistor, which has a voltage across it, what does equation say the current will be?Drizzy said:zero
Drizzy said:but we just said that the current is going to be zero too because of the voltmeter.. so how can an am meter burn when currint is almost zero?
CWatters said:The amp meter would burn if the volt meter wasn't also in the wrong place.
Inga problem.Drizzy said:can you draw a picture to the discription that the book had? an example where the amp meter would born...
...and not burn
You are quite welcome.Drizzy said:oh now i get it. the books picture confused me :p thanks for explaining!
