Circular Motion and artificial gravity
To determine the rotation rate of a space station wheel with a diameter of 135 m providing artificial gravity of 3.80 m/s², the centripetal acceleration formula a_c = v²/R is applied. The calculated linear velocity (v) is approximately 16.02 m/s. Using the relationship between linear velocity and the period, T = 2πR/v, the period is found to be about 26.48 seconds per revolution. However, the calculation mistakenly interprets the period as the frequency, leading to confusion in unit conversion. The correct approach requires ensuring the distinction between period and frequency to find the accurate revolutions per minute.
mkwok
A space station, in the form of a wheel 135 m in diameter, rotates to provide an "artificial gravity" of 3.80 m/s^{2} for persons who walk around on the inner wall of the outer rim. Find the rate of rotation of the wheel (in revolutions per minute) that will produce this effect.
answer must be in rev/min
a_{c}=\frac{v^{2}}{R}
VT=2piR
3.8=\frac{v^{2}}{135/2}
v=\sqrt{3.8/67.5}=16.0156m/s
then since VT=2piR
T=2piR/v = 2pi(67.5)/16.0156 = 26.4813 rev/sec
converting that to rev/min is (26.4813 rev/sec)*(60sec/min) = 1588.88rev/min
however, I think I am doing something wrong, my online homework website tells me this is incorrect
This gives you seconds/revolution, not revolutions/second. Check your units. You're calculating the period here, not the frequency.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
9K
