Deriving Velocity and Normal Reaction in a Vertical Circular Motion
The discussion focuses on deriving expressions for the velocity (v) and normal reaction (R) of a particle moving in a vertical circular motion inside a hollow sphere. The expressions derived are v = [u^2 - 2ga(1 + cos T)]^1/2 and R = mu^2/a - mg(2 + 3cos T). It is established that if u^2 is greater than 5ga, the particle will leave the sphere, with the condition cos T = (u^2 - 2ga)/3ga. The trajectory analysis shows that when the particle leaves the sphere, the angle OA is 45 degrees, leading to a quadratic equation in tan T. The participant is seeking help to identify a potential error in their calculations, suspecting a sign issue.
jiboom
2) a particle P of mass m moves in a vertical circle along the smooth inner surface of a fixed hollow sphere of internal radius a and centre O,the plane of the circle passing through O. The particle is projected from the lowest point of the sphere with a horizontal velocity u. when OP makes an angle T with the upward vertical,the velocity of the particle is v and the normal reaction between the particle and the sphere is R.Find expressions for v and R...done
v=[u^2-2ga(1+cos T)]^1/2 R=mu^2/a - mg(2+3cos T)
show if u^2,5ga the particle leaves the sphere where
cos T=(u^2-2ga)/3ga
if the particle leaves the sphere at a point A and its trajectory meets the sphere again at a point B such that AM is a diameter of the sphere show OA makes an angle of 45
from first part i have
cos T=(u^2-2ga)/3ga
v^2=[u^2-2ga(1+cos T)]
so when particle leaves sphere i get v^2=agcosT
now I am saying the angle of projection is equal to angle OP makes with upwards vertical,so from P to O we have
horizontal distance=asinT
vertical distance=acosT
for the projection
x=-tvcosT
y=tvsinT-gt^2/2
when x=-asinT => t=a(tanT)/v
so
-acosT=atanTsinT-g/2[(atanT)^2/(v^2)]
-acosT=atanTsinT-g/2[(atanT)^2/(agcosT)]
-2=2tan^2T-tan^2Tsec^2T
-2=tan^2T(2-sec^2T)
-2=tan^2T(2-1-tan^2T)
tan^4T-tan^2T-2=0
(tan^2T-2)(tan^2+1)=0
which is close as I am after tan T=1. is there an obvious error in my working?i hoping I am on right tracks but have dropped a sign somewhere?
anyone able to spot my error here?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
