Circular motion with friction and banking - resultant forces
A car traveling at 76 m/s on a circular track with a radius of 111 m, mass of 2500 kg, and a 21° banking angle experiences various forces. The calculations for the centripetal force (Fc) and frictional force (Fk) yield values of approximately 130090.09 N and 4723.75 N, respectively. The net force required for uniform circular motion is equal to (mv²)/r, which is identified as Fc, emphasizing that Fc represents the net force rather than a single force. The discussion also highlights the confusion surrounding the derivation of certain formulas used to calculate forces, with a suggestion to start from a free body diagram (FBD) to clarify the forces acting on the car. Understanding these concepts is crucial for solving problems related to circular motion with friction and banking.
exi
A car travels 76 m/s around a circular track with a 111 m radius.
The car's mass is 2500 kg, the track is angled at 21°, and the coefficient of friction is 0.18.
What is the magnitude of the resultant force on the car and driver, expressed as kN?
Double-checking my work here to see if I'm understanding this correctly.
If:
Fk = µ*Fn
Fn = mg/cosΘ
Fc = mv²/r
Then:
Fc = 130090.09 N
Fk = 4723.75 N
Which leaves me with two questions: Is the above correct, and what am I leaving out of the forces before summing them?
editing this to add: I've gotten a series of formulas that produce the correct answer, but I do not know where they are derived from. If anyone could help explain this, I'd appreciate it.[/color]
1. A = \frac {m(v^2cos\theta - grsin\theta)}{r}
2. B = \frac {mg + Asin\theta}{cos\theta}
3. (\mbox{Answer expressed in kN}) = \frac {Acos\theta + Bsin\theta}{1000}
You're going around your butt to get to your elbow. ;-)
If an object is moving in uniform circular motion, the NET force on that object must be equal to (mv^2)/r. You have this value recorded as Fc. You should note that Fc is NOT a single force, but rather is the NET force on the object in question.
The three formulas you've listed end up spitting out the exact same value as Fc, although in a very convoluted way.
Oh wow, you're right - what I did in the first 30 seconds answered the problem, but I didn't know I actually had the answer. I had to call someone in class with me who was given that formula system by a physics tutor.
That's... definitely something. :shy:
hallo exi may you explain the set of fomulas listed below the senteces in red...@all...i have a problem in calculatiion of forces in a free body diagram...any body who can help?
We have to start from a FBD.
Try to find the forces which act on the car.
