Classical physics Time dependent vector calculation
wavecaster
If A is a time dependent vector, calculate
\int_{t1}^{t2} dtA(t) \times \frac{d^2A}{dt^2} [\itex]<br /> <br /> <h2>Homework Equations</h2><br /> <br /> <br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> I think we should somehow relate it with something&#039;s derivative.<br /> <br /> \int_{t1}^{t2}A(t)\frac{d^2A(t)}{dt^2}dt=<br /> A(t)\int_{t1}^{t2}\frac{d^2A(t)}{dt^2}dt-\int_{t1}^{t2}\frac{dA(t)}{dt}\left ( \int \frac{d^2A(t)}{dt^2} \right )dt=<br /> A(t)\frac{dA(t)}{dt}\left.\right|_a^b\int_{t1}^{t2}\left ( \frac{dA(t)}{dt} \right )^2dt=<br /> A(t2)\frac{dA(t)}{dt}\left.\right|_t_{2}-A(t1)\frac{dA(t)}{dt}\left.\right|_t_{1}-\int_{t1}^{t2}\left ( \frac{dA(t)}{dt} \right )^2dt
Your Latex seems to have blown up. Would you like to edit the OP and try asking your question again?
Hint: before posting, use the Preview Button to check the appearance of your post and correct as required.
$$\int_{t1}^{t2}A(t)\frac{d^2A(t)}{dt^2}dt=
A(t2)\frac{dA(t)}{dt}\left.\right|_{t_2}-A(t1)\frac{dA(t)}{dt}\left.\right|_{t_1}-\int_{t1}^{t2} \left ( \frac{dA(t)}{dt} \right )^2dt$$
Your notation is a bit horrible, you really should not write ##A(t)## outside of the integrals and you are missing the ##\times## from the original expression - making it unclear whether or not it is a cross product or a scalar product. The approach with using partial integration does make sense (and in case of a cross product, what is ##\dot A \times \dot A##?). However, it is not necessary to use partial integration as you can rewrite ##A\times \ddot A## directly as the total derivative of something. What total derivative would have the given term as one of its terms? What would be the value of the other term?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
