Reactor Physics Study: Coding Tips
In summary: What code do you suggest for a novice reactor physicist?I suggest using the code PANACEA-11 from GE/GNF. It is free and can be accessed from many places.
vatly
Do you know any code for reactor physics study ?
Could you elaborate a bit on what field/aspect you're interested in ?
vatly said:
Do you know any code for reactor physics study?
Like PerennialII mentioned, what exactly do you want to do?
There are commercial core simulator packages like SIMULATE-IIIK (from Studsvik-Scandpower), PRESTO, and one package FORMOSA from North Carolina State University, Electric Power Research Center.
SIMULATE-IIIK requrires data from the CASMO lattice code (also from Studsvik), and PRESTO (PRESTO-B for BWRs) is used with CPM (CPM-3) lattice code.
A little background on FORMOSA
A methodology has been developed whereby a three-dimensional (3-D) geometry, nodal expansion method (NEM), pressurized water reactor (PWR) core simulator model is collapsed to form an equivalent two-dimensional (2-D) geometry model that preserves approximately, but with negligible loss of fidelity, the global quantities and axially integrated reaction rates and surface currents of the 3-D model. In comparison with typical licensed-quality 3-D models, the 2-D collapsed NEM model typically requires a factor of 50 less computational time and exhibits root-mean-square (rms) assembly relative power fraction errors, as compared with the original 3-D model, of 5 × 10-3 over an entire fuel cycle, and average maximum errors over the fuel cycle of 1 × 10-2. The collapse methodology includes a pin reconstruction methodology, which exhibits assemblywise rms pin power errors of 5 × 10-3 and average maximum assemblywise pin power errors of 1.2 × 10-2. When coupled with FORMOSA-P's existing assembly power response generalized perturbation theory reactor core simulator, this permits loading-pattern evaluations at a speed approximately 100 to 150 times faster than full, 3-D models, providing the computational efficiency needed for efficient incore fuel management optimization using stochastic methods.
- FORMOSA-P Three-Dimensional/Two-Dimensional Geometry Collapse Methodology purchase the article from ANS.
FORMOSA-P may be available for a small fee - a lot less than SIMULATE. I believe PRESTO is obsolete. FORMOSA is developed by the group under Paul Turinsky, who is also head of the Nuclear Engineering Department as NCSU.
One can also do nuclear calculations with MCNP.
Are you interested in LWR cores, Liquid Metal Fast Reactor (LMFRs), GCR/GCFR's or all three types?
Additional information -
PDQ (Group Diffusion Reactor Computation Code)
ANISN (One-Dimensional Discrete Ordinates Transport Code System with Anisotropic Scattering) - http://www-rsicc.ornl.gov/codes/ccc/ccc2/ccc-254.html
DOT/DORT/TORT - (conventional radiation transport codes from RSICC)
Twodant/Threedant/DANTSYS (available from Nuclear Energy Agency (NEA - OECD) or RSICC(IS))
see - http://www.nea.fr/abs/html/ccc-0547.html
see - http://www-rsicc.ornl.gov/codes/ccc/ccc5/ccc-547.html
Academic institutions should have access to this package
PHYSOR conference held every 2 years.
PHYSOR2002 - http://physor2002.kaist.ac.kr/ - International Conference on the
New Frontiers of Nuclear Technology : Reactor Physics, Safety and High-Performance Computing
PHYSOR2004 - http://www.physor2004.anl.gov/ - The Physics of Fuel Cycles and Advanced Nuclear Systems: Global Developments
PHYSOR2006 - http://www.cns-snc.ca/physor2006/physor2006.html
Vendor proprietary reactor core physics packages
PHOENIX/ANC - BNFL/Westinghouse (Alpha/Phoenix/ANC) for PWRs
TGBLA-6/PANACEA-11 - GE/GNF for BWRs
WIMS/ PANTHER - British Energy/Tractebel.for PWR - see OF WIMS/PANTHER CALCULATIONS WITH
MEASUREMENT ON A RANGE OF OPERATING PWR[/url] pdf
PHOENIX/POLCA-7 or CASMO-4/POLCA-7 for BWRs - see VTT- http://www.vtt.fi/inf/pdf/symposiums/2003/S230.pdf
MCNP Code
How i can get Registered version of Reactor code MCNP to utilize it for research purposes?
http://laws.lanl.gov/x5/MCNP/index.html
One should be able to obtain MNCP from Radiation Shielding Information Computational Center (RSICC) or OECD-Nuclear Energy Agency (NEA).
http://www-rsicc.ornl.gov/codes/ccc/ccc7/ccc-710.html or
http://www-xdiv.lanl.gov/PROJECTS/DATA/nuclear/doc/ccc-710.html
http://www.nea.fr/abs/html/nea-1733.html
One must request the code. However, access may be restricted to academic and scientific institutions.
I am a novice, then I care about some free codes for students. I am caring about some code to compute reactor physics like neutron distribution, lattice calculation, thermohydro calculation ... Thanks for the above news, anyway.
What is reactor physics study?
Reactor physics study is a branch of nuclear engineering that focuses on understanding the behavior of nuclear reactors through principles of physics, such as nuclear reactions, fission, and radiation transport.
Why is coding important in reactor physics study?
Coding is important in reactor physics study because it allows for the simulation and analysis of complex physical phenomena that occur in nuclear reactors. This helps engineers and scientists to design, optimize, and operate reactors more efficiently and safely.
What are some coding tips for reactor physics study?
Some coding tips for reactor physics study include using a high-level language such as Python or MATLAB, understanding the underlying physical principles and equations, and using efficient algorithms and data structures to handle large amounts of data and calculations.
Are there any specific codes or software used in reactor physics study?
Yes, there are several codes and software used in reactor physics study, such as SCALE, MCNP, and Serpent. These codes are specifically designed for nuclear reactor analysis and have been extensively tested and validated by the scientific community.
Is coding the only aspect of reactor physics study?
No, coding is not the only aspect of reactor physics study. It is an important tool, but reactor physics study also involves theoretical and experimental research, data analysis, and design and operation of nuclear reactors.
  • Nuclear Engineering
