Coefficient of kinetic friction and constant acceleration
A child's slide problem involves calculating the coefficient of kinetic friction (μk) given a slide length of 5 meters and a height of 3 meters, with a final speed of 6 m/s. The initial attempt calculated acceleration as 3.6 m/s² and used incorrect angles and forces in the equations. Corrections were made to the angle, confirming it should be 36.9°, and the normal force was recalculated. The final calculations yielded μk values of 0.35 and 0.3, indicating discrepancies in the solution process. The discussion emphasizes the importance of accurate force analysis and angle determination in friction problems.
addy899
A child's slide is flat, 5 meters long, and sloped down so that the top is 3 meters higher than the bottom. A child slides down, starting from rest, and has v = 6 m/s at the bottom. Find the coefficient of kinetic friction, μk is:
F=ma
f=μkFN
v2=v02+2aΔx
use above equation to find constant a=3.6m/s2
3-4-5 triangle, so θ= 30°
free body diagram gives:
FN=mgcos30
and using f=ma,
Fnet=3.6m = mgsin30-μkFN
the masses cancel out to give 3.6 = gsin30-μkgsin30
solving for μk gives 0.153
my key says the answer is 0.3
Think that bit through again.
The angle here is not correct.
You don't even need to calculate the value for the angle since you already have the length of the sides.
the masses cancel out to give 3.6 = gsin30°-μkgsin30°
The second sin here is not correct - it should be cos as you worked out previously.
θ=36.9°
ok, since we already know the length of the sides, we get
3.6 = 5 - 5cos(36.9)μk
5 is the force from gravity parallel to the slide
5cosθ is the normal force perpendicular to the slide
this gives me μk=.35
3.6 = gsin(θ)-μkgcos(θ)
gives
3.6 = (10)*(3/5) - μk*(10)*(4/5) (don't need to work out θ)
gives 0.3
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
