Coefficient of Kinetic Friction
To determine the coefficient of kinetic friction for a box sliding down a 30.0-degree ramp with an acceleration of 1.20 m/s², a free body diagram is essential. The forces acting on the box must be analyzed in both the x and y directions to find the normal force and frictional force. The equation μk = fk/Fn can be used, where fk is the kinetic friction force. The problem requires understanding the relationship between mass, normal force, and acceleration to find a solution. A mathematical approach is necessary to derive the coefficient of kinetic friction effectively.
daliberataaa!
A box slides down a 30.0 degree ramp with an acceleration of 1.20 m/s^2. Determine the coefficient of kinetic friction between the box and the ramp.
μk=f sub k/Fn
With the information I have, I have no samples in my physics book or anything. I ohnestly don't know where to start.
I would start by drawing a free body diagram.
Edit: Fixed spelling
Is there a mathematical solution though?
What do I need to get to solve this? Do I need mass? Normal force? what?
k well...i have searched the glossary of my book, searched the internet since 3 pm.
Yes there is an analytical solution to the problem. Draw the free body diagram and write out the sum of the forces in both the x and y directions.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
