Coeffiecent of Kinetic Friction Problem
A car traveling at 15 meters/second comes to a stop in 4 seconds, prompting a discussion on calculating the coefficient of kinetic friction. The coefficient is determined using the formula friction divided by normal force. The initial calculation of time to stop divided by velocity yields approximately 0.2666, while the expected answer is around 0.38. Participants clarify that to find the friction force, one must apply Newton's second law, focusing on the deceleration caused by friction. The discussion concludes with a participant successfully resolving their confusion regarding the problem.
c.melissas
1. A car is traveling at 15 meters/second on a horizontal road. The brakes are applied and the car sids to a stop in 4 seconds. The coefficient of kinetic friction between the tires and the road is
2. Coefficient of kinetic friction = friction / Normal Force
3. Time to stop / Velocity = 4/15 = .2666. The correct answer is roughly .38, but I have no idea on how to arrive at that.
Where does this equation come from? v = at. Solve for a, then apply Newton's 2nd law to the car.
Thanks for the help. I really had no idea how to answer this problem. I am confused on what do after solving for acceleration because I could not find a way to determine the force or the mass of the car.
You may not need to know the mass, write out Newton's 2nd for the car. The force acting on the car is the friction force, which is slowing it down (decelerating it) to a stop.
And by the way,welcome to PF!
Thank you, and I was able to figure it out.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
