Coherent States of Harmonic Oscillator
decerto
Given the coherent state of the harmonic oscillator |z>=e^{-\frac{|z|^2}{2}}\sum_{n=0}^\infty\frac{z^{n}}{\sqrt{n!}}|n>
compute the probability for finding n quanta in the sate |z> and the average excitation number <z|n|z>
|z>=e^{-\frac{|z|^2}{2}}\sum_0^\infty\frac{z^{n}}{\sqrt{n!}}|n>
Probability=|<n|z>|^2
Average excitation number = <z|n|z>
For the first part I did |<n|z>|^2=|e^{-\frac{|z|^2}{2}}\sum_{m=0}^\infty\frac{z^{m}}{\sqrt{m!}}<n|m>|^2
=|e^{-\frac{|z|^2}{2}}\sum_{m=0}^\infty\frac{z^{m}}{\sqrt{m!}}\delta_{nm}|^2
=|e^{-\frac{|z|^2}{2}}\frac{z^{n}}{\sqrt{n!}}|^2
=|e^{-|z|^2}\frac{z^{2n}}{n!}|
=e^{-|z|^2}\frac{|z|^{2n}}{n!}
Which is correct but was I right in using m to specify a different energy eigenstate to n to obtain the kroncker delta?
For the second part I am not sure how to even write out the problem. Should the eigenstates in |z> and <z| be |n> or something different
What I think is that it should be is
<z|n|z>=e^{-\frac{|z|^2}{2}}\sum_{m=0}^\infty\frac{z^{\dagger m}}{\sqrt{m!}}e^{-\frac{|z|^2}{2}}\sum_{m'=0}^\infty\frac{z^{m'}}{\sqrt{m'!}}<m|n|m'>
But I am not sure what <m|n|m'> is equal to, \delta_{nm}\delta_{nm&#039;} maybe?
Im getting e^0 which isn't the right answer as per page 2 of this http://www.phas.ubc.ca/~joanna/phys501/coherent-states.pdf
Any help would be great.
The first part is correct.
About your question regarding the second part, Pay attention that n=a^\dagger a and a^\dagger |n&gt;=\sqrt{n+1} |n+1 &gt; and a |n&gt;=\sqrt{n}|n-1&gt;.
Likes decerto
decerto said:
For the second part I am not sure how to even write out the problem. Should the eigenstates in |z&gt; and &lt;z| be |n&gt; or something different
&lt;z|n|z&gt;=e^{-\frac{|z|^2}{2}}\sum_{m=0}^\infty\frac{z^{\dagger m}}{\sqrt{m!}}e^{-\frac{|z|^2}{2}}\sum_{m&#039;=0}^\infty\frac{z^{m&#039;}}{\sqrt{m&#039;!}}&lt;m|n|m&#039;&gt;
You pretty much have it, except that by definition n |m&#039;\rangle = m&#039; |m&#039; \rangle. So \langle m |n| m&#039; \rangle = m&#039; \langle m | m&#039; \rangle.
This gives me m' as the answer but the answer is |z|^2?
Nvm got it using the ladder operators
No, it doesn't give m&#039; as the answer, because m&#039; is summed over. Since \langle m | n |m&#039; \rangle = m&#039; \delta_{m, m&#039;}, you have something like:
e^{-z^2} \sum_{m=0}^\infty \sum_{m&#039;=0}^\infty \frac{z^m z^{m&#039;}}{\sqrt{m! m&#039;!}} m&#039; \delta_{m,m&#039;}
Because of the \delta_{m, m&#039;} the second sum simplifies to just one term, the one where m&#039;=m.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
