How Much Sucrose Is Needed to Lower Water's Vapor Pressure by 2 mmHg?
  • Thread starter sw3etazngyrl
  • Tags
    Properties
In summary, colligative properties are physical properties of a solution that depend on the number of particles present, rather than the type of particles. These properties affect the freezing and boiling points, as well as the osmotic pressure, of solutions. The main factor that affects colligative properties is the concentration of solute particles, with temperature and pressure also playing a role. Colligative properties can be used to indirectly determine the concentration of a solution and have practical applications in various industries and everyday life.
sw3etazngyrl
How many grams of sucrose (C12H22O11) must be added to 552 g of water to give a solution with a vapor pressure 2.0 mmHg less than that of pure water at 20 degrees C? (The vapor pressure of water at 20 degrees C is 17.5 mmHg.)
I tried it out, and this is my work.
change in P=mole fraction*P in degrees
2.0mmHg=X(17.5mmHg)
X=0.11 moles
552 g H2O * 1 mole/18.02g = 30.3 mol
0.11(30.3 + x)=30.3
3.33+0.11x=30.3
x=245.18 mol
245.18 mol sucrose * 324.34g/1 mol=83000
Hello sw3etazngyrl, we need to first see your effort. https://www.physicsforums.com/showthread.php?t=94384
.4 g or 83 kg
Based on the given information, the solution would require approximately 83 kilograms of sucrose (C12H22O11) to be added to 552 grams of water to achieve a vapor pressure 2.0 mmHg less than that of pure water at 20 degrees C. This calculation takes into account the colligative properties of the solution, specifically the decrease in vapor pressure caused by the addition of a solute. It is important for scientists to understand colligative properties in order to accurately predict and control the behavior of solutions, as well as to develop various applications in fields such as chemistry, biology, and engineering. Further experimentation and analysis may be necessary to determine the exact amount of sucrose needed for the desired change in vapor pressure, as other factors such as temperature and solute-solvent interactions may also play a role.
Related to How Much Sucrose Is Needed to Lower Water's Vapor Pressure by 2 mmHg?
1. What are colligative properties?
Colligative properties are physical properties of a solution that depend on the number of particles present in the solution, rather than the type of particles. These properties include vapor pressure lowering, boiling point elevation, freezing point depression, and osmotic pressure.
2. How do colligative properties affect solutions?
Colligative properties affect the physical behavior of solutions by changing their freezing and boiling points, as well as their osmotic pressure. This can have practical applications, such as using salt to lower the freezing point of water for making ice cream, or using antifreeze to raise the boiling point of engine coolant.
3. What factors affect colligative properties?
The main factor that affects colligative properties is the concentration of solute particles in the solution. As the number of solute particles increases, the colligative properties also increase. Temperature and pressure also play a role in affecting colligative properties.
4. Can colligative properties be used to determine the concentration of a solution?
Yes, colligative properties can be used to indirectly determine the concentration of a solution. By measuring the change in colligative properties, such as freezing point depression or osmotic pressure, the concentration of the solution can be calculated using equations like the van't Hoff equation.
5. What are some real-world applications of colligative properties?
Colligative properties have many practical applications, such as in the food industry for preserving and freezing food, in the automotive industry for engine coolant, and in the production of pharmaceuticals. They are also important in everyday life, such as when using salt on icy roads to lower the freezing point of water.
12K
12K
  • Biology and Medical
22K
10K
