Collision problem with a spring
  • Thread starter Thread starter PinkDaisy
    Collision Spring
The discussion revolves around a physics problem involving a compressed spring, two blocks, and a frictionless hill. For part (a), the speed of block1 before the collision was calculated to be 14.0 m/s using energy conservation principles. The user expresses uncertainty about how to approach part (b), which involves finding the speeds of both blocks after the collision, factoring in the coefficient of restitution of 0.50. They seek clarification on how gravitational potential energy and the coefficient of restitution affect the equations used in the calculations. The conversation highlights the complexities of energy conservation and collision dynamics in this scenario.
PinkDaisy
The problem is:
A spring that is compressed 0.5m by a block (block1) are at the top of a 10m tall frictionless hill. The block is released and slides down the hill where it collides with block2, which started at rest. (a) What is the speed of block1 prior to the collision? (b) Find the speeds of both blocks following the collision assuming that the coefficient of restitution is 0.50.
mass of block1 = 10kg, mass of block2=15kg, and spring constant k=500N/m
So for (a) I got:
mgh + .5mv(i)^2 = .5mv(f)^2
(10)(9.8)(10) + (.5)(10)(0) = (.5)(10)(v^2)
v=14.0 m/s
I'm not sure where to even start with part b.
Thanks
If mass1 if sort of 'fired' away by the spring, then the kinetic energy when it is released is equal to the potential energy from the spring.
Isn't there also a component due to gravitational potential energy?
Does the equation start out looking like this:
.5m(1)v(1)^2 + m(1)gy + .5kx^2 + .5m(2)v(2)^2 = .5m(1)v(1)^2 + m(1)gy(init) + .5kx^2 + .5m(2)v(2)^2
0 + m(1)gy + .5kx^2 + 0 = .5m(1)v(1)^2 + 0 + 0 + .5m(2)v(2)^2
How does the coefficient of restitution come into play?
