Collision of Balls - Coefficient of Restitution
  • Thread starter Thread starter prateek_34gem
    Balls
In the discussion about the collision of three balls, a third ball collides with two stationary equal balls, which remain at rest post-impact. The coefficient of restitution is being calculated, with options provided for the correct value. The user attempted to solve the problem using conservation of momentum and the coefficient of restitution equations but arrived at an incorrect answer of 1/2. The correct coefficient of restitution is determined to be 2/3, raising questions about the accuracy of the provided answer in the textbook. The focus remains on understanding the dynamics of the collision and the application of relevant physics principles.
prateek_34gem
Two equal balls are in contact on a table and are in equillibrium. A third ball collides with them simultaneously, symetrically and remains at rest after the impact. The coefficient of restitution is :
A)2/3
B)3/2
C)1/3
D)1/2
i hav tried by combining the masses and velocities of the two balls at rest then found e. like the collision of two bodies ( considering two bodies as one ) .
You have 2 equations that you would satisfy don't you?
Conservation of momentum which gives you the relationship between the initial velocity of the first ball and the final velocity of the second 2.
Then you have the equation for the coefficient of restitution that relates the before and after velocities of the 2 bodies. (This is simplified by the fact that before the collision only 1 was in motion. And after the collision the first becomes stationary.)
but there are two balls lying at rest do i hav to consider the motion of only one of thm or take them whole as one ?
i hav got e=1/2
but thts wrong ans . Correct ans . is 2/3
is ans given in book wrong or i am wrong ??
