Combination Circuit Question: Determining Current
The discussion focuses on calculating the current through each resistor in a circuit with a total voltage of 14V and various resistances. The overall resistance was calculated as 8.031Ω, leading to a total current of 1.743A. The participant is struggling to determine the individual currents for the resistors, particularly for those in parallel and series combinations. Clarifications provided emphasize using Ohm's Law (V=IR) to find voltages across resistors and subsequently calculate the currents. The discussion highlights the importance of understanding the relationships between voltage, current, and resistance in complex circuits.
Zaphia
Find the current flowing through each of the resistors in the circuit shown, where \xi = 14V and R=6.3\Omega.
I=V/R
where I=current (Amps), V=potential different (Volts), R=resistance (\Omega).
Resistors in Series:
Req=R1+R2+...
Ieq=I1=I2=...
Veq=V1+V2+...
Resistors in Parallel:
1/Req=1/R1+1/R2+...
Ieq=I1+I2+...
Veq=V1=V2=...
Step 1: Determine the overall resistance of the circuit.
6.3\Omega and 5.8\Omega are in series, so Req=12.1\Omega so far.
Next, 12.1\Omega and 3.2\Omega are in parallel, so the resulting Req is: 1/Req=1/12.1\Omega+1/3.2\Omega=2.531\Omega.
Finally, 2.531\Omega, 1.0\Omega and 4.5\Omega are in series. So Req=2.531\Omega+1.0\Omega+4.5\Omega=8.031\Omega
The total resistance of the circuit is 8.031\Omega.
Step 2: Determine the overall current, I.
Using Ohm's equation, I=V/R, I found that I=1.743A
Step 3: Determine the individual currents at each of the resistors.
This is the part that I can't figure out. I know that resistors 4.5\Omega and 1.0\Omega have current, I=1.743A because the current travels from positive to negative, but I don't understand how to solve for the currents for the rest of the resistors.
I also understand that the resistors 6.3\Omega and 5.8\Omega will also have the same current.
(I have been given the correct answers for all of the resistors, but I can't reverse-solve the problems either:)
6.3\Omega and 5.8\Omega, I=0.365A
3.2\Omega, I=1.38A
Thanks for any insight!
Your REQ calculation and source current calculation looks correct.
Notice that the voltage across (R = 3.2 ohms) is the same as the voltage across the combination (R = 6.3 + R5.8 ohms). You combined those in series, then parallel in your earlier work and got (R = 2.53) ohms as a result. The voltage across that combination resistor will tell you the voltages across the re-expanded elements (R = 3.2 ohms) and
(R = 6.3 + 5.8 ohms). Let me know if I need to clarify, I know that probably sounds confusing.
I understand (I think!) what your saying, but I don't know the math in order to solve the problem. Is it a set of ratios to get the Current values for each resistor?
You just need to use Ohm's Law V = IR. You can determine the voltage across the resistor combination I was talking about in the previous post because you will know the current through it and the equivalent resistance. You solved for those values earlier, ISource = 1.74 A and REQ = 2.53 ohms, from your calculation below.
Zaphia said:
Next, 12.1\Omega and 3.2\Omega are in parallel, so the resulting Req is: 1/Req=1/12.1\Omega +1/3.2\Omega =2.531\Omega.
Use those values to determine the voltage across that equivalent resistive element, then expand the circuit back to its original form. Then you will have the voltages across the resistor (R = 3.2 ohms) and the resistor combination (R = 6.3 + 5.8 = 12.1 ohms). You can use the calculated voltage value and the resistor values to determine the two unknown branch currents.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
