Common rail high pressure pump
The discussion revolves around the operation of common rail high pressure pumps, particularly focusing on how pressure is controlled when the engine is spinning but no throttle is applied, such as when going downhill. Participants explore the implications of pressure control mechanisms and the behavior of the pump under these conditions.
  • Charly questions what happens to fuel flow and pressure when the pressure control valve is fully closed while the pump is still spinning, particularly if this leads to a vacuum or continued pressure increase.
  • Some participants mention different systems for pressure control, including one that returns fuel to the tank and another that uses an Mprop to control the inlet of the high pressure pump.
  • There is a suggestion that if the Mprop is fully closed, the pressure in the rail should drop due to less fuel being moved by the plunger pump, but this raises questions about whether the plunger can stop moving fuel entirely without creating a vacuum.
  • Charly expresses a need to understand this behavior to achieve a specific operational goal of getting the rail up to pressure without opening any injectors for an extended period.
Participants express uncertainty regarding the behavior of the pump and the implications of the pressure control mechanisms. There is no consensus on whether the plunger can completely stop moving fuel without creating a vacuum, and multiple viewpoints on the operation of the systems are presented.
Participants have not fully explored the assumptions behind the operation of the pressure control systems, and there are unresolved questions about the mechanics of fuel movement and pressure dynamics in this context.
Charly Segaert
Hello everyone,
I have a question about a common rail high pressure pump.
Most common rail pumps make use of a pressure control-valve which controls the amount of fuel that goes to the plunger. This way it is possible to control how much fuel goes to the rail, so it controls the pressure.
But... If you are going downhill without giving any throttle (no injector opens for a while), the engine still spins and therefore the pump spins as well. When the pump spins, but the pressure control-valve is fully closed, what happens? Is there a minimum amount of fuel that always goes to the plunger? And doesn't this keep on pushing more fuel in the rail, thus increasing pressure? Or doesn't the plunger get any fuel at all, creating a kind of vacuüm?
It's a small thing I don't yet understand. Thanks in advance
Charly
There are a number of ways used to control pressure. Isn't the most common to return the fuel to the tank?
Well, I heard of 2 systems:
One where a pressure control valve is mounted on the rail to open and close the return line.
Another where an Mprop opens and closes the inlet of the high pressure pump.
I make use of the second system. If the Mprop is fully closed, pressure in the rail should drop because less fuel is moved by the plungerpump.
But if you give no throttle going downhill, no fuel leaves the rail. Yet the high pressure pump still spins because the engine does. So if you want the pressure to drop, the plungerpump shouldn't pump any more fuel till throttle is applied again. But to do this, the plunger shouldn't move any fuel at all, and this would result in a vacuum. Is it possible?
I know it's a strange question, but I need it because i have to get a rail up to pressure without opening any injectors for a long time.
Greetings
Greetings
https://www.dieselnet.com/tech/diesel_fi_common-rail_control.php
  • · Replies 39 ·
24K
  • · Replies 32 ·
14K
  • · Replies 17 ·
  • · Replies 28 ·
