Comparison of Electric and Magnetic Forces
The discussion focuses on comparing electric and magnetic forces between two positive point charges moving parallel to each other. The key equation derived is the ratio of the magnetic force to the electric force, expressed as Fmag/Felec = v1*v2/c^2, where v1 and v2 are the velocities of the charges and c is the speed of light. Participants emphasize using the Lorentz force and the Biot-Savart law to determine the magnetic field generated by one charge and the subsequent magnetic force on the other charge. Understanding how the speed of light relates to these forces is crucial for solving the problem. This analysis is essential for mastering concepts in electromagnetism for upcoming exams.
godiva
Suppose that the instantaneous velocities of two positive point charges are parallel. Compare the electric and magnetic forces. Show that the ratio of the magnetic force (Fmag) to the electric force (Felec) is: Fmag/Felec = v1*v2/c^2
Where v1 and v2 are the velocities of particle 1 and particle 2 respectively, and c is the speed of light.
F = qE + qv*B
I know that you need to use the Lorentz force in some form, but I am confused as to how the speed of light is incorporated into the solution. This is a practice problem for my exam later on this week, so any help would be appreciated.
Hello godiva,
Welcome to Physics Forums!
The easy way is to first figure out what the magnetic field B is, caused by the first moving particle (charge q moving at a speed of v1). Use the Biot-Savart law for a single particle. If you are using the general Biot-Savart law that is a function of current and wire length, substitute (current times length of wire) with (charge of particle times velocity of particle), which is the same thing for a single particle.
Once you know the magnetic field caused by the first particle, find the magnetic force on the second particle as it moves through the magnetic field with a velocity v2.
Then take the ratio of magnetic force to the electric force.
Finally, note that c = 1/\sqrt{\mu _0 \epsilon _0}
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
