Complicated (for me) differential equation problem
Mathn00b!
1. I am supposed to find dx and dy. I think I am missing a step or a general idea. I spent quite some time figuring out what rules should I use and the only sequence I can think of is quotient rule and chain on the (x2 +y2)1/2 term. The answer that I find is ((xy(3x2+2y2))/(x2+y2)3/2 . On the other hand I found that wolfram alpha solves it with the y'(x) term that I cannot understand, since it should find the only x terms. Please find the attached wolfram alpha solution. I am not asking for a solution (step by step) just some guidance.
Here is a link to the wolfram alpha's solution : http://i1375.photobucket.com/albums...x2ysqrtx2y2_--2015-04-20_1952_zpskiujuryl.jpg
The solution given is:
((xy(x2+2y2))/(x2+y2)3/2
Thanks you!
You've provided the solution - but you also have to provide the problem. I had to go to a different webpage to discover it ... am I correct that the problem was:
$$\frac{d}{dx} \frac{x^2y}{\sqrt{x^2+y^2}}$$ ... if so then you need all the rules:
product, quotient, power, and chain rules - as well as those for implicit differentiation... so go revise.
For instance, you can put ##f(x,y(x))=xy^2(x)## and ##g(x,y(x))=\sqrt{x^2+y^2(x)}## and use the quotient rule right off.
This will give you a relationship between other derivatives which you have to use other rules to evaluate.
i.e. $$\frac{d}{dx}xy^2 = y^2\frac{d}{dx}x + x\frac{d}{dx}y^2\\ \qquad = y^2 + x\left(\frac{d}{dy}y^2\right)\left(\frac{dy}{dx}\right)\\ \qquad = y^2 + 2xy\frac{dy}{dx}$$ ... see how that worked?
The first line was just the product rule, the second line used the chain rule.
Note: Wolfram gave you step-by-step instructions ... did you try following them?
I also want to make sure that the derivative you are after is the exact derivative and not a partial derivative... i.e. do we understand y to be a function of x?
Likes Mathn00b!
Thanks for the reply! I tried to follow the wolfram's solution, but I got confused why they keep all the ys, I just thought that you can disregard the ys. I actually am after the partial derivative. First have to find ∂ƒ/∂xand after that for ∂ƒ/∂y. Sorry for the fact I missed to provide the problem. For some reason couldn't edit the 1st post, here is the problem:
Find (∂ƒ/∂x , ∂ƒ/∂y) for the following function:
ƒ(x,y) = x2y / √(x2+y2)
You probably will not like my advice, but I suggest strongly that you avoid using programs such as Wolfram Alpha, and do everything by hand, at least at the beginning while you are still learning and practicing the methods. That really is the only sure way to learn the material.
In this case, to evaluate ##\partial f(x,y)/\partial x##, just treat ##y## like a constant---that is what partial derivatives do. So now you need to differentiate ##g(x) = y x^2/\sqrt{x^2 + y^2}## with ##y = \text{const.}##. This is really not much different from differentiating something like ##g(x) = 2 x^2/\sqrt{x^2+4}##.
Likes Mathn00b!
Yes, I know its not a good practice, just wanted to see where I made a mistake, but it showed even more complicated solution and I got lost. Anyway, I found where I was wrong. It is at the differentiation of the y/√x2+y2 . I found confusing the notation with the substitution of u = x2 + y2 and all the notations d/du and du/dx . Thank you for the replies, hope I am walking in the right direction!
Yep - with partial derivatives, it's much easier than when y has to be treated as a function of x and differentiated implicitly.
The u-substitution, in this case, was just application of the chain rule... that would be the usual way to do it.
Leibnitz notation can be tricky to get used to... one of the realizations you need is how it behaves like a fraction sometimes as in:
$$\frac{dy}{dx} = \frac{du}{du}\frac{dy}{dx} = \frac{dy}{du}\frac{du}{dx}$$ ... it's actually a more useful notation.
Another handy trick is to make square roots into power of a half so: $$\frac{1}{\sqrt{x+y}}=(x+y)^{-1/2}$$ ... then it's chain-rule and power rule.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
