Finding g with a Compound/Physical Pendulum: Plotting and Calculating
  • Thread starter Thread starter Pete2008
    Pendulum
To find the acceleration due to gravity using a compound pendulum, the formula T=2π*sqrt(I/mgh) is utilized. The discussion focuses on plotting the period T against the moment of inertia I, as the variable is changed by adjusting the mass along the rod. The relationship can be rearranged into the linear form y=mx+c, where T is on the y-axis and I on the x-axis. The gradient of the resulting line can then be used to calculate g. This method effectively links the physical properties of the pendulum to gravitational acceleration.
Pete2008
Find the acceleration due to gravity using a compound/phyiscal pendulum. Using the formula: T=2pie*sqrt(I/mgh)
I understand how to find all the variables but to find g, i must plot a graph of T against something (Thats where i need help) and use the gradient of the line to calculate g.
so.
1.What do i plot against T
2.How would i calculate g from the gradient of the line
Thanks.
Hi Pete and welcome to PF,
Firstly, what is the general equation of a straight line?
Hi,
The equation of a staright line is y=mx+c, and i guess that T would be the y axis/ the y part of the equation. Would the x-axis of the graph be I, because that's the variable I am changing by moving the mass along the rod?
Once I know the x and y part of the equation would it just be a case of rearanging the origional formula into y=mx+c?
Thanks
Pete2008 said:
Hi,
Thanks
Absolutely spot on :approve:
Thanks alot
Pete2008 said:
Thanks alot
No problem, I didn't do anything...:rolleyes:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
