Compute acceleration on an inclined plane with friction
The discussion revolves around calculating the acceleration of an object on an inclined plane with friction, given specific parameters such as mass, height, length, and the coefficient of kinetic friction. The problem also extends to finding the speed of the object at the bottom of the incline.
  • Mixed
  • Participants explore the interpretation of the incline's dimensions and question the validity of the provided acceleration value. There is discussion about the relevance of mass and the angle of the incline in the calculations. Some participants also raise questions about the second part of the problem regarding the speed at the bottom of the incline.
The discussion is active, with participants providing insights and questioning assumptions. Some have offered alternative approaches to the problem, while others are still seeking clarification on how to address the second part of the question. There is no explicit consensus on the correct approach or interpretation yet.
Participants note potential ambiguities in the problem setup, such as the interpretation of the incline's dimensions and the impact of friction on energy transfer. The original poster's reliance on an answer key is also mentioned, which may not align with the reasoning presented in the discussion.
Jim Bob
A 24 kg object is placed at the top of an incline with height 500m and length 375m. The coefficient of kinetic friction is 0.600
1) Find the acceleration of the object.
2) Find the speed by the time it has reached the bottom of the inclined plane.
F_g = Force of gravity on the object
F_N = Normal force
F_// = Parallel force (force applied to the object parallel to the inclined plane and towards the bottom of the inclined plane)
F_p = Perpendicular force (force the object exerts on the inclined plane perpendicularly to it)
F_k = force of kinetic friction
See the attachment, the answer key says acceleration=8.33646 but I got a different number
Length normally would mean the hypotenuse, but clearly that is not possible. I see you have taken the 375m as a horizontal extent, which is a reasonable interpretation.
This makes it a 3-4-5 triangle.
That seems to be 85% of g. It would not be that high even without friction.
I agree with your answer, but you can get there much faster. The mass is irrelevant, and it is almost always unnecessary to find the angle.
You have (4/5)g-0.6(3/5)g=(11/25)g.
What about the second problem? How would I do that?
What equations do you know that apply to motion under constant acceleration?
Oh I got it now!, KE=mv^2/2 and PE = mgh so since all PE is transferred to KE by the end, mv^2/2=mgh and solving for v gives v=sqrt(2gh).
What about the friction?
  • · Replies 19 ·
  • · Replies 19 ·
