Compute Electric Field from Electric Currents
The discussion focuses on computing the electric field components E_x, E_y, and E_z from a given equation involving electric currents. Participants clarify the dot product calculation for J*R, confirming it should include all components (J_x, J_y, J_z) multiplied by their respective R components. The symbol "|" is discussed, with suggestions that it represents a scalar multiplication involving R and C_2 after computing J*R. Additionally, the handling of complex numbers in C_1 and C_2 is addressed, with advice to perform calculations in the complex domain and interpret results accordingly. The conversation emphasizes understanding the formula's origin for better clarity on its application.
ggeo1
Hello,
I have this equation that computes the electric field from electric currents.
E=-j*k_n (J*C_1- (J*R|R*C_2) e^ -j*k*R/4πR )
The data are:
k_n=377 , k=20.93 , R=Sqrt(3) ,J_x=0.72576821 ,J_y=0.03763659 , J_z=0.86104220 ,
C_1=0.999239077741 + 1 / 36.2518234024j
C_2=0.997717233223+ 3 / 36.25182344024j
R_x=R_y=R_z=0.57735026919
I have 3 questions.
1) From the above equation i must compute E_x ,E_y,E_z.
When i compute E_x i will compute J_x*C_1 - (J*R|R*C_2) ?
And specific: I will compute the J*R dot product as : J*R=J_x*R_x+J_y*R_y+J_z*R_z ?
Or only the J*R=J_x*R_x ?
2) The computation J*R|R*C_2 . How will i do the computation for the symbol ' | ' ?
I will compute the dot product , then the R_x*C_2 and then what?How to compute the whole
J*R|R*C_2 ?
3) How to deal with the C_1 and C_2? I mean they have the imaginary part in the denominator.What is the best approach?
Thank you!
Mathematics news on Phys.org
What does the symbol "|" represent? It does not look like standard notation.
C_2 is a scalar? In this case, both J*R and C_2 are scalars, and I would assume that you can just perform a scalar multiplication with your vector.
Don't forget the exponential which is multiplied with the latter term.
You should do this, right.
1/10 does not look high, but I would perform the whole calculation with complex numbers. If the result is not real, try to find an interpretation - maybe you can simply drop the imaginary part.
Hello and thanks for the help.
C_1 and C_2 are scalars.
So, ok J*R=..=scalar.
But i can't understand how to do the (J*R|R*C_2) .
I will compute the J*R and then the R*C_2 , and then what?
I think it's
((J*R) *C_2 )*R , where R i will put R_x?
Then for E_y i will put R_y?
I would try to just multiply them as scalar*vector.
(\vec{J}*\vec{R}|\vec{R}*C_2) \stackrel{?}{=} \left(C_2 (\vec{J}*\vec{R})\right) \vec{R}
Edit:
I think it's
Should work.
It is speculative, and maybe you should check where the formula comes from.
Ok , thanks!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
