Compute Fourier Transform of x/(x^2+1)^2 using e^|x|
saxen
Using that the Fourier transform of e^{|x|} is \frac{2}{\xi^2+1}. Compute the Fourier transform of \frac{x}{(x^2+1)^2}
My first thought was to try and rewrite the problem in a form I recognized, tried a couple of things but what I though was best was to write:
\frac{d}{dx} \frac{-1}{x^2+1}
And transform that to e^{i*\xi}*f(\xi). This was wrong. Very wrong actually.
Anyone have any hints for me?
thanks!
edit: Missed some things but should be right this time.
susskind_leon said:
http://en.wikipedia.org/wiki/Fourier_transform#Functional_relationships Is has nothing to do with convolution! Fourier transform turns DERIVATIVE into MULTIPLICATION with i times argument, so i \xi in this case, so the result should be something like i \xi e^{|x|} (i assume you are supposed to perform the inverse FT, right?
Hello sussking_leon,
My bad, the * means multiplication and not convolution. How do you get the i \xi infront of the exponent?
Check the wiki page, forumla 106 and 107 do the trick. So if FT{e^|x|} = f(v), then FT{x e^|x|} = i d/dv f(v). (Fourier transform non-unitary, angular frequency)
Ah, I was thinking right at least. Its so stupid, we don't get any of these rules on our exam so without wiki, I would have never solved this exercise. Thanks for the help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
