Conceptual Q: Angular Momentum
Angular momentum, represented as L = r x p, is significant as it describes the rotational motion of an object around an axis, in this case, the z axis. When an object like a dreidel spins, its angular momentum is perpendicular to its axis of rotation, which influences its motion. In a frictionless environment without gravity, a perfectly vertical dreidel will not move or stop, as there are no external forces acting on it. However, if the dreidel is tilted at an angle under gravity, it will eventually come to a stop due to gravitational torque acting on it. Understanding these principles clarifies the behavior of rotating objects in different conditions.
tolove
L = r x p
What's the significance of angular momentum, L, acting along the z axis? Angular momentum is being compared to translational momentum, p = mv, but translational momentum is acting the same direction of the velocity, right?
Thanks for any help!
edit: this is a nice gif:
http://en.wikipedia.org/wiki/File:Torque_animation.gif
Angular momentum along the z axis means that the object is rotating about the z axis. The velocity of the particles is perpendicular to the axis of rotation, hence L=rxp.
I think I understand what you're saying. Just hit a section about precessional motion. I think this will fill in the blanks when I get through it.
Closing my book for tonight I think~
Thank you very much for your reply
Alright, not sure I completely understand this concept yet. Could you answers these questions for me?
A dreidel is spinning away, no resistance from air or friction from surface (or anywhere else). It mas mass, angular speed, etc. Nothing special about it.
1) The dreidel is placed perfectly perpendicular on top of a horizontal surface. If there is no gravity, will the dreidel move in any way or eventually come to a stop? Of course not, right? The graphs of L acting on z were confusing me, though.
2) The dreidel is placed at a slight angle away from perpendicular on top of a horizontal surface, under gravity. Will the dreidel eventually come to a stop?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
