Conceptual question about longitudinal waves
The discussion centers on the relationship between phase difference and path length in sound wave interference. It explains that when two sound waves from different sources are in phase and travel different distances, the phase difference \(\phi\) can be expressed as \(\frac{\phi}{2\pi} = \frac{\Delta L}{\lambda}\), where \(\Delta L\) is the difference in path lengths. The derivation involves the equations of the waves, showing that the phase difference arises from the difference in distances traveled. This relationship clarifies how variations in path length affect wave interference. Understanding this concept is crucial for grasping wave behavior in physics.
Saladsamurai
So we are working on sound waves in my physics course now and I was doing some textbook reading. I have been following it pretty well, but I just came across a relationship that I am not quite following.
It is with reference to wave interference. Let us say that two sound waves are emitted from two different point sources S_1 and S_2. The waves have the same wavelength \lambda and are in phase at their sources. They take paths of lengths L_1 and L_2 and pass through point P.
The text says that their phase difference \phi is dependent on \Delta L=|L_1-L_2|
Thus to relate the variables \Delta L and \phi we can use the proportion: \frac{\phi}{2\pi}=\frac{\Delta L}{\lambda}
I know that I should see it, but I don't exactly follow this proportion.
Could somebody ellaborate on this a little for me? I sure would appreciate,
Casey
Suppose the equation of both waves is: y = Acos(kx) (going along the direction the wave is travelling)
The wavelength of this wave is 2*pi/k
So at the point of interest, suppose wave 1 has traveled L1, and wave 2 has traveled L2:
y1 = Acos(kL1)
y2 = Acos(kL2)
the phase of the first wave is kL1. the phase of the second is kL2.
phase difference is: kL1 - kL2 = [2*pi/wavelength]*(L1 - L2)
so from this we get the phase difference relationship.
y1 = Acos(kL1)
y2 = Acos(kL2)
Ah. I see that now. Thanks LP. It makes even more sense now that I wrote out what you did^^^...the phase difference is \phi
Casey
