Conceptual Question About Vertical Spring System
The discussion centers on the behavior of a mass-spring system when a mass is released from rest. It explores the relationship between gravitational force and spring force at equilibrium, questioning how energy equations apply in different scenarios. When the mass is released, the equilibrium point can be defined as x=0, leading to the equation mg = kx when acceleration is zero. The conversation also clarifies that whether the mass is released or slowly lowered, the stretch of the spring at equilibrium remains consistent, represented by x = mg/k. Ultimately, the system's behavior aligns with energy conservation principles, regardless of the method of lowering the mass.
lvslugger36
Suppose there is a spring with a mass m attached to it, and it is released from rest. It will oscillate, starting from a certain point y0, going back to equilibrium and then down to let's say y2. Let's say in the first case, I call y1 my x = 0 point for the spring. When it passes equilibrium, is it not true that mg = kx since the acceleration is zero? However, let's repeat the case for which i will call the equilibrium point the x=0 for the spring. Now, from energy we have: mgx = kx^2/2. This means that 2mg = kx. How can this be possible?
yes
You are mixing apples and oranges. For the 2nd case, the mass has kinetic energy at x= 0 (point y1). You are better off using the energy equations from the starting point y0. Then from the 2 'no speed' positions (at release and at the end point when the mass comes to a temporary stop), then mg(2x) = 1/2(k(2x)^2 , k = mg/x. Note that the stretch is double the stretch if the mass was slowly lowered to its final at rest position y1.
Thanks for your help; that's brilliant. However, wouldn't the stretch be the same even if it was lowered? For the first equation: x = mg/k. For the one slowly lowered, since the forces are balanced once it reaches equilibrium, shouldn't the stretch be x = mg/k also?
Yes. When it is slowly lowered with your hand applying an external force, then you release it once it reaches it's equilibrium position, the stretch is mg/k. Or, if it is damped due to friction, it will ultimately, after oscillating back and forth a few times, settle to that same point, x =mg/k.
