Conservation of Energy crate and ramp
A factory worker released a 230 kg crate from rest at the top of a 4.3 m ramp inclined at 40°, with a kinetic friction coefficient of 0.37. To determine the crate's speed at the bottom of the ramp, one must calculate the acceleration using the forces acting on the crate. The approach involves applying Newton's second law to find the net force and subsequently the acceleration. Once the velocity at the ramp's end is established, the distance the crate slides on the factory floor can be calculated using its kinetic energy and the frictional forces. Understanding these principles is crucial for solving the problem effectively.
Dynex
A factory worker accidentally releases a 230 kg crate that was being held at rest at the top of a ramp that is 4.3 m long and inclined at 40° to the horizontal. The coefficient of kinetic friction between the crate and the ramp, and between the crate and the horizontal factory floor, is 0.37. (a) How fast is the crate moving as it reaches the bottom of the ramp? (b) How far will it subsequently slide across the floor? (Assume that the crate's kinetic energy does not change as it moves from the ramp onto the floor.)
Thankz for the help in advance!
Hi Dynex
How did you try to solve it?
My approach would be:
1. Draw the situation!
2. Calculate the velocity of the mass at the end of the ramp
3. With the given friction and the velocity from 2. you should be able to get the distance the crate slides on the floor.
If this does not help you, please give me / us more information what your problem exactly is, what was your attempt etc.
Yannick
P.S. I hope my English is understandable...
In order to find v, you'll need to find a. Then you can apply this equation to find v:
a(x-x0)=½(v²-v0²)
x0 and v0 will be 0. So...
ax=½v²
To find a, add up all the force vectors acting on the box (treated as a point).
F=ma=Wsin(θ)-μN where W=mg and N=Wcos(θ)=mgcos(θ)
=mgsin(θ)-μmgcos(θ)
=mg(sin(θ)-μcos(θ))
so...
a=g(sin(θ)-μcos(θ))
