Conservation of Motion Collision of two object
The discussion revolves around a physics problem involving the conservation of momentum during a collision between a small car and a larger cart. The small car, with a mass of 0.2 kg, collides with a stationary 3 kg cart, and after the collision, the small car recoils at 0.850 m/s. The user attempts to calculate the final speed of the larger cart using the momentum conservation equation but arrives at an incorrect answer. The key point raised is that this is an elastic collision, meaning the two carts do not move together post-collision, which is crucial for correctly applying the conservation principles. The user seeks clarification on their mistake in the calculations.
kbward
A small car is moving at 1.3 m/s on an air track when it collides with a larger 3 kg cart at rest. After the collision, the small cart recoils at 0.850 m/s.
What is the speed of the large cart after the collision?
m1V1i + m2V2i = (m1+m2)V2f
m1 = .2 kg
m2 = 3 kg
V1i = 1.3 m/s
V2i = 0
V1f = -.85 /ms
V2f = ?
.2*1.3 + 3*0= (.2+3) V2f
.26 = 3.2 V2f
V2f = .26/3.2
V2f = .08125
My answer came back wrong. Where am I making a mistake?
Thanks
If this is an elastic collision, then the carts don't move together after the collision.
