How Long Does It Take for Velocity to Change Under Constant Acceleration?
The problem involves an object with a constant northward acceleration of 40 m/s² and an initial westward velocity of 15 m/s. To determine when the magnitude of the velocity reaches 30 m/s, the x and y components of velocity must be considered, as the acceleration only affects the northward (y-axis) component. Using the Pythagorean theorem, the required y-component velocity to achieve a resultant of 30 m/s is found to be 26 m/s. The time to reach this y-component velocity is calculated using the formula t = (vf - vi) / a, resulting in 0.65 seconds. The solution emphasizes the importance of accounting for directional components in problems involving vectors.
Tipolymer44
I need help on this homework problem I can't seem to figure it out.
A objects constant acceleration is north at 40 m/s^2. At time 0 its velocity vector is 15 m/s west at what time will the magnitude of the velocity be 30 m/s?
This is the eq i used: delta T =(Vf-Vi)/a
I set Ti as 0.
So I got 30-15/40= .375 secs
I also tried subtracting gravity from acceleration to give (30-15)/(40-9.8) =.496 secs
These are apparently wrong. what should i be doing?
there is direction involved here so you cannot just pluck values into a formula
so the question nicely sets north (y-axis) and west (x-axis) for you.
so question wants the time when the MAGNITUDE of velocity is 30m/s, which means your x and y components of the velocity, will have to give you a resultant of 30m/s
notice your x-component velocity of 15m/s doesn't change since there is no acceleration in this direction, acceleration is only towards north (y-axis)
so in order to find the y-component velocity THAT will give you 30m/s resultant velocity, you have to use Pythagorean theorem as it is a triangle. draw it out and you will see
so its 302 = 152 + y2, where y is your velocity in y-axis direction
so solving, y = 26m/s
so now you use your formula ALONG THE Y-direction
time taken = { vf,along y-axis - vi, along y-axis } / a along y-axis
which is
(26 - 0) / 40 = 0.65s , the initial velocity is 0 because the object is moving west, there is no y-direction velocity
ahhh, so i basically need to formulate the directional components before i can solve for t
yes.
