Constructing a Wall Imaging Device
The discussion revolves around the feasibility of constructing a wall imaging device that uses sound waves to identify objects within a wall, such as cabling and studs. Participants explore various existing technologies and their potential applications in this context, focusing on low-cost solutions and the principles behind them.
  • One participant proposes building a device that uses a speaker to generate sound on one side of a wall and a receiver on the other side to create an image of what is inside the wall.
  • Another participant mentions existing devices that use radar to look into the ground, suggesting that similar technology could be applicable.
  • A participant clarifies that the proposed device would not be for underground use, as access to both sides of the wall is available, and expresses uncertainty about the specific technology or name for such a device.
  • One participant references a method used for locating underground utilities, which involves an exciter source and a probing device, but notes that it may not provide a visual representation of the wall.
  • Another participant suggests that the concept may be akin to a medical sonograph, focusing on the transmission of sound rather than reflection.
Participants do not reach a consensus on the specific technology or method that could be used for the proposed wall imaging device. Multiple competing views and ideas are presented without resolution.
There are limitations regarding the definitions of the technologies discussed, as well as the assumptions about their applicability to wall imaging. The discussion does not resolve the technical feasibility or the specific requirements for constructing such a device.
nanoWatt
I was wondering if it was possible to construct a certain device. There would be a speaker on one side of a wall generating a certain frequency, and on the other side a receiver that would give an image of what was in the wall, such as cabling, studs, etc. I'm sure the technology exists, but I would like to build something relatively inexpensive. I don't need a whole lot of resolution. Just enough to tell what's there.
They have such devices. It looks into the ground using radar. I saw it on CSI, it's got to be true.
Actually, it won't be in the ground, as I have access to both sides of the wall. Just something to measure the sound intensity as it comes through in different points, and give that an image of sorts. I know it exists, but I'm not sure what it's called, or how to build it.
There is something they use with locating underground utilities that uses the same basic application. However, it doesn't provide a picture of the wall. Essentially you place an exciter source at a distance away from you. You then use a device that is very similar to a metal detector and probe the area. I can't say if it would work with walls, but it may be something to look at.
It seems to me that this is a variation of a medical sonograph; it just relies upon transmission, rather than reflection, of the beam.
  • · Replies 19 ·
  • · Replies 49 ·
