Convert Litres to Moles: Step-by-Step Guide
  • Thread starter Thread starter ChemRookie
    Moles
To convert liters to moles, additional information such as the substance's density or concentration is required, as liters measure volume while moles measure the amount of substance. The equation n_m = (Vρ)/(N_Am) can be used if density and molar mass are known. For ideal gases at standard temperature and pressure (STP), 1 mole is approximately equal to 22.4 liters. In practical applications, such as calculating vapor pressure, the relationship between mass and moles is crucial, with the formula moles = mass/molar mass being essential for conversions. Understanding these concepts is fundamental in chemistry for accurate calculations.
ChemRookie
How would you go about changing liters, like 1L into moles?
Thanks
You can't.Liters measure capacity or volume of fluids especially,while moles measure amount of substance.
Concentration is sometimes given in moles/liter.
Daniel.
Are you given the name of a substance in the liquid or solid phase? What about a density? If so, you can convert by way of:
n_m=\frac{V\rho}{N_Am}
where V is the volume in liters, \rho is the density in kg/m3, NA is Avogadro's number, and m is the mass of an individual atom or molecule of your substance.
Without this information, however, dexter is right that the two can't be converted.
Again, I am only adding to what dextercioby and SpaceTiger have already said. It is not possible to convert a volume to a mole unit without another factor. Dextercioby said one of them (concentration) and SpaceTiger said the another way to work it out.
Going on what dextercioby said:
Moles \ (mol) = Volume \ (dm^3) \ \times \ Concentration \ (mol \ dm^3)
With concentration you can work out the number of moles. (Take note that the dm3 can be changed for any volume value if you know the conversion factors).
The Bob (2004 ©)
mol \ dm^{-3},okay ?Or u can use the fraction line.
Daniel.
I'm not sure what sort of question you're looking to answer. The above posts are completely correct in that it doesn't make sense to convert moles to liters directly.
However, if you're learning about basic chemistry or thermodynamics and you're looking to change an IDEAL GAS from moles to liters, then you have the following equation:
22.4\text{L}\approx 1\text{mol} for ideal gases at STP
This "constant" is due to the fact that ideal gases are presumed to be point masses and statically neutral at STP and therefore exhibit similar properties despite being different molecules. If it's not an ideal gas, you'll need the concentration, as others have said.
the info I have is:
a 1L container with 5mL of water helt at 20degcel
I need to find the vapour pressure. I'm supposed to use PV=nrt right?
how do I get n though?
U got the volume of water,u need the # of moles.
18 ml of water<------>18 g of water<------>1 mol
Daniel.
Daniel.
huh?
I don't get it.
ChemRookie said:
huh?
I don't get it.
One gram of water is the same as 1ml of water.
You know that you have 5 ml but let's pretend you have 18ml (you will see why in a minute).
You can convert 18ml into 18g because it is water. Other substances will needed a different change factor.
Now you know the molecular formula of water (with is H2O). The molar mass of this is 18g ml-1.
To convert from mass to moles you have to use the equation:
moles \ (mol) = \frac{mass \ (g)}{molar \ mass \ (g \ mol^{-1})}
Therefore, 18g divided by 18g ml-1 is equal to 1 mole.
Use this equation find how many moles of water there are in 5 ml.
The Bob (2004 ©)
Can I just make sure that ChemRookie realizes that 'ml' means millilitres, not moles? I'm not convinced that there isn't some confusion going on here!
The Bob (2004 ©)
thanks..now I get it.
's alright. :smile:
The Bob (2004 ©)
Thanks
It isn't that hard, I think you just divide the element by the STP which is 22.4, and then you got your moles :wink:. You have to know a little chemistry though to know some of this but it really isn't that hard once you learn it.
by the way, do ChemRookie really understand the concept of moles, as he asked that question is the first place. if he don't, latter on he might use 18 to measure other things.
ChemRookie said:
the info I have is:
Wrong.
You do NOT need it.
how come? explain..what formula do I use then?
IF "5 ml" is 5 gm, rather than releasing 5ml water vapor in the liter container, you are dealing with a two phase system, water vapor in equilibrium with liquid water. The vapor pressure is determined by temperature alone.
Formula? You come up with one, and the Nobel committee will hand deliver your prize. You get vapor pressure from tables in which the blood, sweat, and tears of lab boffins from the last 150 years have been compiled, fit, reviewed, interpolated, cubic-splined, and converted from this system of units to that.
