Converting from square to polar coordinants
  • Thread starter Thread starter Bob19
    Polar Square
The equation x^2 - 2y = 0 is correctly converted into polar coordinates as r^2 * cos(φ)^2 - 2r * sin(φ) = 0. It is noted that as long as r is not zero, the equation can be simplified by dividing through by r, resulting in r cos^2(θ) - 2sin(θ) = 0. This leads to the expression r = 2sin(θ)/cos^2(θ). Additionally, it is customary to use "θ" instead of "φ" in polar coordinates. The discussion emphasizes the correct conversion and simplification process in polar coordinate transformations.
Bob19
Hi
If I have the following equation:
x^2 - 2y = 0
I need to convert it into polar coordinants:
r^2 * cos(phi)^2 - 2*r* sin(phi) = 0
Is this correct ?
/Bob
Yes, it is correct.
Bob19 said:
Hi
x^2 - 2y = 0
Is this correct ?
/Bob
And, of course, as long as r is not 0, you can divide through by r to get
r cos^2(\theta)- 2sin(\theta)= 0
or
r= \frac{2sin(\theta)}{cos^2(\theta)}
(It is customary to use "theta" in polar coordinates rather than "phi")
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
