What are the equations for whistling in a convoluted tube?
  • Thread starter Thread starter manjagu
    Resonance Tube
The discussion focuses on the equations governing whistling in convoluted tubes, commonly used in cable management and medical devices. It highlights the phenomenon of "impinging shear flow instability," which occurs when air flows over corrugated surfaces, creating vortices that produce sound. This effect is similar to how a tea kettle whistles, with the tube's ridges playing a crucial role in sound generation. The relationship between airflow speed and sound frequency is emphasized, noting that faster airflow results in higher pitch sounds. For precise numerical methods, participants are encouraged to research "impinging shear flow instability."
manjagu
Does anyone know what the equations governing the effects of whistling in a convoluted tube as air passes trough it are? I didn't know it was called this until today, but a convoluted tube is the real name for what many cable management tubes are. These tubes are also used in medicine for things like ventilators. You used to be able purchase large ones as a toys, which you could twirl around above your head. The faster you twirl them, the higher pitch whistle you could get out of it.
Thanks!
manjagu, Welcome to Physics Forums!
The toy you mention can be purchased here:
Whirlies
An introduction to whirled music
http://www.exo.net/~pauld/summer_institute/summer_day13music/Whirly.html
The convoluted tube that produces sound is also used as a golf swing practice device described in this patent:
Golf swing practice system with convoluted tube
http://www.patentgenius.com/patent/6503149.html
For an excellent description of how it works see this from the Exploratoruim:
Aerodynamics researchers in Japan put a whirly in a wind tunnel and used very tiny hot wire anemometers to measure the airflow near the corrugations.
They discovered that air flowing over two successive corrugations in the wall of the whirly experienced "impinging shear flow instability."
This is the same effect that makes a tea kettle sing. If you look at the spout of a teakettle you will see that it has two disks separated by a short gap, each with a hole in its center. When the air, or steam, flows through the first hole and then flows through the second hole it exits in vortices which cause oscillating pressure in the air, heard by the human ear as a whistle. The ridges in the whirly tube play the same role. As the air flows first over one ridge then over a second it tumbles into a vortex. The faster the air flows through the tube the higher the frequency of the sound produced by the vortex. When the frequency of the vortex matches one of the natural resonant frequencies of the tube it is amplified.
http://isaac.exploratorium.edu/~pauld/activities/AAAS/aaas2001.html
If you still need the exact numerical methods to describe this you may search for
“Impinging shear flow instability”.
Cheers,
Bobbywhy
Thanks for the thorough response! Very helpful.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
