How Do You Determine the Tension in Cable ABD and the Reaction at Support C?
  • Thread starter Thread starter mayeh
    Equilibrium
To determine the tension in cable ABD and the reaction at support C, it's essential to analyze the forces acting on the frame, particularly focusing on the upward force T and the leftward force T at the respective points. Neglecting friction simplifies the problem, allowing for a straightforward application of equilibrium equations. By summing the moments around the fulcrum and considering the forces acting on the system, the correct tension can be calculated. The discussion concludes with a confirmation that the method used yields the correct answer, aligning with the solution provided in the reference material. Understanding these principles is crucial for accurately solving similar problems in mechanics.
mayeh
Neglecting friction, determine the tension in cable ABD and the reaction at support C.
http://www.imagevimage.com/images/Picture1.jpg
help.. i don't have any idea to solve for the tension so that i could solve for the component force c
Try forgetting that there's a string and a pulley; think instead of a force T acting upward at the LHS of the horizontal part of the frame and a force T acting leftward at the top of the vertical part of the frame.
[Forget also that the leftward force would make the frame slide on the fulcrum! Think of it as a hinge instead]
Can you write the sum of moments?
yeah.. thank you.. i got the right answer.. same as the book..
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
