Corrosion of Steel: Equilibrium & Rate Drop
  • Thread starter Thread starter supasupa
    Corrosion Steel
When a piece of steel is placed in still water, the corrosion rate decreases over time as the system reaches equilibrium. This reduction in rate is attributed to the formation of a protective layer of corrosion, or rust, that slows further corrosion. In contrast, corrosion rates are higher in moving water because the protective oxide layer is continuously removed. This principle is similar to the theory behind anodizing aluminum, where aluminum oxide provides both protection and thermal insulation. The discussion highlights the importance of protective layers in mitigating corrosion rates.
supasupa
Say is a piece of steel is placed in still water and is corroding. Why will the corrosion rate drop away after time??
Is it because the system reaches some sort of equlibrium??
thats ment to say : "Say if a piece of steel..." NOT " Say is a piece..."
I believe the layer of corrosion protects it. Corrosion rates are higher in moving water because the corrosion covering is always being washed away.
that makes sense... what you are saying is the oxide around the steel (rust) slows down the corossion rate
That is correct. This is the theory behind anodising aluminium (although aluminum oxide also exhibits excellent thermal insulation properties)
