Calculating Cost of Operating Lamp
  • Thread starter Thread starter GlobalDuty
    Lamp
To calculate the daily cost of operating a lamp drawing 1.90 A from a 110 V line, the formula used is current multiplied by voltage, cost per kWh, and hours in a day. The initial calculation resulted in $0.310992, but this was identified as incorrect. The correct approach requires rounding to the nearest tenth, leading to a suggested answer of $0.30. The importance of precision in the final answer is emphasized, as the problem specifically requests it to the nearest dime. Accurate calculations are essential for determining energy costs effectively.
GlobalDuty
Compute the cost per day of operating a lamp that draws a current of 1.90 A from a 110 V line. Assume the cost of energy from the power company is $0.0620 / kWh. NOTE: Enter your response with tenths precision.
1.90*110V*.0620*24 = .310992
but this answer is wrong
you did divide by 1000 W/kW, but the problem asks for the answer to the nearest tenth (nearest dime).
yeah i divided by 1000 at the end, but .3 is wrong
Try $0.30
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
